Old 04-28-2002, 08:27 PM   #1 (permalink)
Throttle Body Bypass: $2.79
I got bored today and decided to go to home depot and see if I could come up with a homemade Throttle body coolant bypass. Amazingly, the parts I needed were only 6 feet from each other and cost a grand total of $2.79. I bought a small brass pipe about 2 inches long, threaded on both sides. I also bought 2 hose clamps. Took about 10 minutes to install. All of the parts are by the sinks and faucets. Saved $17
SteveYelloZ06 is offline   Reply With Quote
Old 04-28-2002, 08:59 PM   #2 (permalink)
Have any pictures??
Frank QS/Black 2001 Z06
Katech Stage II Heads and Cam, Katech Ported and Polished Throttle Body, 36# Injectors, FLP Headers, High Flow Cats and X-Pipe, Vortex Rammer & Power Duct, BPP Performance Shifter, MSD Wires, Beru Spark Plugs, Lloyds Mats, Chrome Z06 Wheels, Euro Tail Lights
....I AM BONE STOCK!!
Sherylann BLK/Black 2001 Z06
Vortex Rammer & Power Duct, Chrome Z06 Wheels, Lloyds Mats, Shortened stock shifter with MOMO knob
fcalmes is offline   Reply With Quote
Old 04-28-2002, 09:02 PM   #3 (permalink)
Kinda like goin' to any hardware store and buying two 1/2"x7" grade 8 bolts for a grand total of $5.00 and saving the $25.00....:rolleyes:
I should start a business selling things at half what most Vette vendors do, I'd still triple my money...
TAMUz06 is offline   Reply With Quote
Old 04-28-2002, 09:07 PM   #4 (permalink)
Washing machine section at home depot has adaptible fittings and hose if you rather go that way. It's amazing how much good stuff is in that place, if you take the time to look. Ric
Old 04-28-2002, 09:09 PM   #5 (permalink)
No pics unfortunately. I dont have a digital camera. The only thing to beware of is that you have to route the hose under the intake in front of the throttle body. Therefore, you must tie it up(with a twistie tie or whatever) to prevent it from sagging to the water pump pulley. I simply suspended it from the hose clamp on the throttle body with a twistie tie. Iloosened the clamp, put on the tie, and tightened it back up. You cant even see it. Beautiful, cheap, easy.
Old 04-29-2002, 10:23 AM   #6 (permalink)
Anyone know what the risk of this bypass is? Why is it designed and built to have the coolant go through the throttle body? Is this to prevent freezing in cold environments? If so, no problem bypassing this in hot weather areas I assume.
Old 04-29-2002, 10:28 AM   #7 (permalink)
Flying Ace
Has anyone ever really measured TB temps? As hot as it gets in Florida I would think that the coolant running throught the TB might actually cool it off in the summer.
Old 05-01-2002, 11:29 AM   #8 (permalink)
Re: Throttle Body Bypass: $2.79
Sounds like what I did on my C4. I was browsing the Halltech site and it looks like their Throttle Body Coolant Bypass Hose Kit
bypasses a coolant line and a vacuum line. You can see that here:
http://www.corvettec5.com/store/?pag...bafc63a57fd04a
and here:
http://www.corvettec5.com/store/Inst...T1/tbcb1-2.pdf
What's up with this? Why are they replacing a vacuum line?
--rb--
ETown # 6291
rbartick is offline   Reply With Quote
Throttle Body Bypass ?? COUTO1981 C5 Z06 - Pit Road 24 06-11-2005 03:31 AM
Throttle Body Bypass??? DarkHelmet C5 Z06 - Pit Road 6 08-26-2003 06:19 PM
throttle body bypass zmerun C5 Z06 - Pit Road 12 08-12-2003 07:55 AM
Throttle Body Bypass DavidGP C5 Z06 - Pit Road 10 01-29-2003 10:22 AM
Throttle body bypass panzer C5 Z06 - Pit Road 6 08-28-2002 05:28 PM
