Old 10-14-2005, 04:41 PM   #1 (permalink)
throttle body install
just purchased a used shaner and looking to install it tomorrow. anything i should look for??it has the black cylinder thing attached too it should i swap mine on to there?? not even sure what its called. i also noticed that the blade is slightly open now. is this normal or will it change once i install it and hook up all the connectors thanks guys
xxsvtcobrakidxx is offline   Reply With Quote
Old 10-14-2005, 04:53 PM   #2 (permalink)
do i need to replace the gasket??
Old 10-18-2005, 06:41 PM   #3 (permalink)
I was wondering the same thing.
mvvette97 is offline   Reply With Quote
Old 10-18-2005, 06:46 PM   #4 (permalink)
Send a message via AIM to BBaxR6
The black cylinder thing is the servo. A new gasket is a good idea. It doesn't matter if the blade is at an angle now when it's off, it'll close once you hook it up and turn the car on. Good luck!
Brandon
SIG by GR8 WHITE
BBaxR6 is offline   Reply With Quote
Old 10-18-2005, 07:35 PM   #5 (permalink)
According to the manual, yes.... I removed mine once and it looked fine so I reused it and had no issues...
C5~Missle is offline   Reply With Quote
C6 Vararam Intake and Throttle Body Spacer Install Wrestle285 C6 Z06 - Grandstand 0 12-22-2005 02:39 PM
f/s throttle body xxsvtcobrakidxx Member Sales - Parts & Cars 1 10-17-2005 11:01 AM
Throttle Body IMBLISS C5 Z06 - Pit Road 6 07-08-2002 03:49 PM
Install of Throttle Body? IMBLISS C5 Z06 - Pit Road 7 06-27-2002 01:07 PM
Throttle body bypass install ? WA 2 FST C5 Z06 - Pit Road 3 01-23-2002 01:13 PM
