Originally posted by itry2hide
Anyone going to the Donutz Motorsports event at Thunderhill on May 31st? This will be my first time at a track, so it would be nice to meet some fellow Z06 board participants.
On another note, what should I do to my car to prepare it for my first track experience? I don't plan on any mods to the car until I spend several hours on the track. Even so, I'm wondering if I should put in different brake fluid and change the brake pads?
Also, what air pressure should I run on my stock tires and rims?
thanks
I normally run with fresh oil and chanign the fluid to something like AP600 or Motul will definitely help. Regarding pads, if you change them before the day make sure that you put some miles on them before the event to break them in - you don't want to be running brand new pads on the track right away.
I run 31/32 cold for stock tyres which seems to be a reasonable compromise. Ideally you set the pressures with the car hot, but if this is your first event then I wouldn't get too hung up about pressures different to stock - they'll be plenty of other factors effecting your day!!!
I run my car pretty much stock with the exception of a K&N filter and find that the Goodyears work great and don't go off significantly throughout the day even under hard use. I will be moving to track tryes/wheels soon those for both performance and cost reasons soon).
I Wish I could make it down to Thunderhill ... you should have a blast. Don't be surprised to see a number of other Z06's - up here in the NW we normally get a contingent of four or five Z06's at any DE day. It seems that Z's and WRX's are the track day toys of choice at the moment!
Have fun - it's an addictive drug.
