Old 06-01-2005, 02:06 PM   #1 (permalink)
blackvetterzo6's Avatar
Tire Pressure
Whats The Stock Tire Pressure On Zo6.
blackvetterzo6 is offline   Reply With Quote
Old 06-01-2005, 02:50 PM   #2 (permalink)
30psi F&R
* Mike Garfias
Old 06-01-2005, 02:50 PM   #3 (permalink)
30 lbs. on all 4 tires (cold)
Old 06-01-2005, 03:08 PM   #4 (permalink)
But that's cold, as in winter air. What about summer air?
ST1100 is offline   Reply With Quote
Old 06-01-2005, 03:08 PM   #5 (permalink)
I've been using 38 psi all around. Is that bad?
Alex
Old 06-01-2005, 03:09 PM   #6 (permalink)
Cold means not having driven on it. I usually check mine in the morning, before the cars been moved, and before its been in the sun.
Old 06-01-2005, 03:26 PM   #7 (permalink)
"Cold" means before the tire heats up from driving it.
Old 06-01-2005, 03:53 PM   #8 (permalink)
DennyM's Avatar
Just an anal comment. I've rolled mine out of the garage into the sun. Sitting out for an hour or so ... pressure on "sunny side" may be as much as 2 lbs higher than "shady side" ... so be advised.
DennyM is online now   Reply With Quote
Tire pressure for 17's all the way around Jose Gonzalez Racing 5 08-25-2002 04:34 PM
Tire Pressure Help GroundFighter The Garage 0 08-04-2002 01:09 PM
Tire pressure for F1's Peterod45 C5 Z06 - Pit Road 12 05-22-2002 08:56 PM
Tire Pressure Jose Gonzalez Racing 2 08-15-2001 02:49 PM
Tire pressure...... ddle The Garage 12 07-11-2001 09:49 AM
