Old 03-04-2006, 01:12 PM   #1 (permalink)
Tire Question
I need to replace my street tires and have decided to buy Michelin Pilot Sport 2's. I also really nicked a front wheel and will buy a set of CCW Classic wheels. I want to decrease the understeer while not exceeding the delta for the active handling system. I would use PS2 295/35YR18's on the rear and 275/35YR18's on the front. I would use CCW 18x10.5 on the rear and 18x10 on the front. My reasoning is that the lower aspect ratio ond slightly wider tire on the front would decrease understeer somewhat. The OEM tire has a diameter of 25.4 inches and the PS2 275/35YR18 has a diameter of 25.6 inches, so I don't believe that this will cause a problem with the active handling system. If I went with a 265/35YR18 front tire the diameter would be the same but there would be more understeer.
This set-up would be used in daily driving with an occasional HPDE. I have tried to think this through carefully and want to make sure that I haven't missed something. I would apprerciate your thoughts on this before I spend the $$$$$$. Thank you.
DavePro is offline   Reply With Quote
Old 03-04-2006, 03:47 PM   #2 (permalink)
I think the PS2's give more grip than the stock GY's. I don't see a problem with the tire sizes you're going with. You should like the PS2's better than the stock tires.
I decided to go a different route, and I love them!
Good luck,
Alex
Old 03-04-2006, 04:51 PM   #3 (permalink)
That is the exact tire setup I have with no issues whatsoever.
Dont think about it, just do it.
Tire question jaxchuck C6 Z06 - Pit Road 4 01-16-2006 05:18 AM
Tire Question fresh_Z06 C5 Z06 - Pit Road 8 09-09-2005 03:03 PM
Tire question Mr. C's 5 C5 Z06 - Pit Road 4 05-20-2005 07:18 AM
My tire blew and I just paid $400 for a new rear tire! Story and Question inside... don527 C5 Z06 - Grandstand 22 09-23-2002 11:34 PM
Tire question mgarfias C5 Z06 - Grandstand 3 05-02-2002 09:49 AM
