Old 04-06-2006, 09:47 PM   #1 (permalink)
Tire size for 19x11.5 wheel.
What's the largest size that I can run? I'm currently running a 315/25/19 tire that's about 1" shorter in diameter than the factory size. The optimal size would be 305/30/19 which would put me at 26.2" total diameter (ideal). Are there any other tire manufacturer's out there that have a tire that would be more ideal for my application and wouldn't look ghetto nor rub? Thanks in advance.
O2Thief86 is offline   Reply With Quote
Old 04-07-2006, 01:47 AM   #2 (permalink)
JETZ's Avatar
A 315 on a 11.5'' will stick out whether 25, or 30 aspect ratio!
A 305 on a 11'' would have been a better choice!
http://www.tirerack.com/
HP. More is good. Too Much is just right!
'Leave late, get there early'!
2004 Z16, #646 of 2025
JETZ is offline   Reply With Quote
Old 04-07-2006, 07:13 AM   #3 (permalink)
I'm not concerned about the tire sticking out, I'm concerned w/ the overall diameter. The 305 will be 0.3" less in total track width vs the 315. Can I fit a 325/25/19 on the 11.5 wheel?
Old 04-07-2006, 11:02 AM   #4 (permalink)
ottoz06's Avatar
I may be wrong but what I've heard is that if you go over 315's you'll have to install mini-tubs. Plus be careful on your wheel offsets. Could also effect the rear brake cooling tube on Z06's (rubbing).
Good luck on your tire search. I'm sure you'll find the perfect ones for your car.
ottoz06 is offline   Reply With Quote
Widest tire for a 19x11 Wheel VICOUS C5 Z06 - Grandstand 11 01-31-2006 10:36 PM
what size tire will fit a 18 x 13 wheel? hugoagogo C5 Z06 - Grandstand 10 11-01-2005 02:54 PM
wheel option and tire size? Alabama C5 Z06 - Grandstand 3 10-06-2005 09:15 PM
Tire/Wheel size calculator NEVR L8 The Garage 1 02-24-2003 01:48 AM
wheel/tire size brad C5 Z06 - Pit Road 2 08-16-2002 12:44 AM
