Old 02-28-2006, 06:06 PM   #1 (permalink)
Tires size for 18x10 front & 18x11 rear wheels?
I am getting ready to order some CCW Classic wheels and I need to figure out the correct tire sizes. I plan to purchase 18x10 wheels for the front and 18x11 for the rear so I can run drag radials.
For the rear I am guessing that 315/30R-18 is the largest I can go without rubbing, but what is the correct size for the front wheels?
Will this size work up front without scraping? 295/35R-18
I'm leaning toward BFG G-FORCE T/A DRAG Radials in the back and BFG G-FORCE T/A KDW NT in the front.
Any input would be appreciated. Thanks!
01 Z06 | TR/Blk | Polished Magnacharger | Stainless Works Headers/X-Pipe Borla Stingers Quad Round Tips | ACI High Rise Hood | CCW Classics (18x10 front & 18x11.5 rear) with BFG KDW's and BFG Drags | B&M Ripper Shifter | AC Delco Durastop Cross Drilled Rotors | MGW Pistol Grip Shifter Knob | Vararam Intake
BOBS97C5 is offline   Reply With Quote
Old 02-28-2006, 06:21 PM   #2 (permalink)
If you care at all about the handling, dont go with the BFG drag radials in the back. The car will handle worse than a Mustang.
Im also curious if 295s will fit in the front.
habib is offline   Reply With Quote
Old 02-28-2006, 06:30 PM   #3 (permalink)
Originally Posted by habib
If you care at all about the handling, don't go with the BFG drag radials in the back. The car will handle worse than a Mustang.
Not only that, they are down right dangerous in the wet.
Old 02-28-2006, 07:02 PM   #4 (permalink)
Hey BOBS97C5,
When I ordered my CCW Classics John advised that 10.5x18 front and 11.5x18 rear was the max advisable, so you can add the extra .5" if you want. I went with the race machining and steel inserts in the lug holes.
I'm running Nitto 555R2's with 295x18 front and 305x18 rear. Rear brake ducts still in place. everything fits great, only rubs on DRM extensions at full lock.
For 315 wide rear I think the rear ducts have to go.
Arnoldir is offline   Reply With Quote
Old 02-28-2006, 07:17 PM   #5 (permalink)
Send a message via MSN to rutiger
let me add a little more info as bob is my buddy. he already knows the caveats to running drags (no wet weather and no high speed cornering), so that's not the question. the issue is that with anything less than R2s you can't hook up when you have more than 450rwhp. i run bfg drags in the summer because it's the only way i can hook up. we have other vehicles for wet weather and we don't go nuts in corners with drags. i actually have pushed my bfgs pretty hard on some twisty roads and was surprised at how well they did. not as good as my R2s, but much better than i thought they'd be. also, i have 315s on 10.5s in the rear with no problems.
just looking for input on tire sizes that others are running if they have 18x10s up front.
i'll be sad to see the 505s go, but you DO need some traction
thanks
03 Z06 579rwhp/469rwtq
06 Jeep SRT8
06 Magnum SRT8
rutiger is offline   Reply With Quote
Old 02-28-2006, 07:45 PM   #6 (permalink)
[quote=Arnoldir]
[quote]
Do you mean 285/35-18 in the front? Nitto doesn't make an RII in 295.
That's the way I'll be going this spring, 18x10.5 on all four corners with the RIIs in 285/35 front and 305/35 rear.
'02 EB/MR Z
80% Track, 20% Driver, 100% Z
Old 03-01-2006, 07:43 AM   #7 (permalink)
Hey Blue Angel,
You are correct 285 on the front, I must be suffering from CRS.
With the 285 the edge of the rim actually sticks out about 2mm past the sidewall, so a 295 should not be a problem.
And yes, if you look closely there is a ding in the rim from a curb. I just put a block of wood on it and pounded it straight.
Old 03-06-2006, 11:08 AM   #8 (permalink)
WHEELS:
So I can run 18x10.5" in the front and 18x11.5" in the rear? Is anyone else running these sizes? Am I safer sticking with 18x10 front and 18x11 rear? I need to know for sure before I order my CCW Classics.
TIRES:
Can anyone say for sure that these tires will fit without rubbing?
Front: BFG g-Force T/A KDW NT - 295/35R-18
Rear: BFG g-Force T/A Drag Radial - 315/30R-18
Thanks!
Old 03-06-2006, 01:45 PM   #9 (permalink)
If you go that route (295/35-18 front, 315/30-18 rear) your fronts will be a larger diameter than the rears (26.1" F and 25.6" R).
Why don't you run the KDW in a 265/35 on an 18x10" wheel on the front, that way it'll be a little smaller than your 315/30 DR (25.3" F, 25.6" R)? The 265/35-18 comes in both the new and traditional tread pattern, too, the new tread matches the new drag radial kinda.
The guys at CCW should be able to help you out... I'd work with them since they're the ones supplying the wheels.
Old 03-06-2006, 02:13 PM   #10 (permalink)
Thanks, that sounds about right. I just looked up all of this info on BFG's website so I can compare overall diameters of different size tires. I just wanted to make sure that whatever I end up going with will not rub. Thanks for the input.
Old 03-06-2006, 07:01 PM   #11 (permalink)
I have 18x11 front and 18x12 ccw rear.
run 315/30/18 Nitto NT-01 in rear and also have run Pilot Cups with no issues at all but damn tight.
305/30/18 in front with a little rub full lock with drm extensions.
New 18X10" & 18X11" wheels now available! ccsteve Member Sales - Parts & Cars 2 06-03-2005 01:58 PM
Can anyone confirm that 285/35-18 tires on 18x10.5 rear stock rims will fit in front Dr Chill Racing 16 12-26-2004 06:59 PM
FS HRE 547R 18X10 & 18X11.5 zohhhsix Member Sales - Parts & Cars 2 07-06-2004 12:00 PM
Using rear wheels/tires on front? bpf1970 Racing 2 04-19-2004 11:03 AM
Why does Chevrolet use different size wheels on the front and rear of the Corvette? NERVOUS C5 Z06 - Pit Road 13 08-08-2002 08:16 PM
