Old 11-07-2004, 09:19 PM   #1 (permalink)
Torque setting
Need to know the torque setting for the oil drain plug & the oil filter.......Thanks..!
Zman
Zman
2008 Black 2LZ Z06 w/Nav
NCM Delivery 5/16/2008 @ 7:45am
zman is offline   Reply With Quote
Old 11-07-2004, 10:43 PM   #2 (permalink)
oil filter = 22 lb.-ft.
drain plug = 18 lb.-ft.
Old 11-07-2004, 10:46 PM   #3 (permalink)
PerforminNorman's Avatar
Wow, you guys actually use a torque wrench?
Come to the Z06 Fest!
Performin' Norman
Old 11-07-2004, 10:47 PM   #4 (permalink)
Send a message via AIM to wantazo6
omg I use hand tight on filter and snug with plug..
2002 Electron blue z06
15.5K miles..
B&B stinger 2-tip.
halltech intake
wantazo6 is offline   Reply With Quote
Old 11-08-2004, 05:48 AM   #5 (permalink)
Torque wrench
Yes, I use a torque wrench. The engine is aluminum, very easy to strip.
wlxx861 is offline   Reply With Quote
Old 11-08-2004, 01:34 PM   #6 (permalink)
NYCHASM's Avatar
Yeah but...like wantazo6 said... "hand tight" and "snug" work for me too...as long as you remember that there are different values for "hand tight" and "snug" depending on whether the block is cast iron or aluminum.
BTW...the oil filter nipple in the block isn't aluminum so "extra hand tight" would work just fine here.
Charlie
Sig schematization by EHS
Old 11-08-2004, 02:39 PM   #7 (permalink)
DennyM's Avatar
Been going "by feel" since I was 12. Filters - oil the seal, hand tight, then, depending on how good a grip one can get by hand, 1/4 to 3/4 turn past that.
Plugs ... depends on the type ... one-use crush washer types are best, but for the Z, with its hard rubber seat, it's to point of resistance, then seat firmly with about 8" of wrench leverage ... just so's it doesn't back out.
Old 11-08-2004, 05:07 PM   #8 (permalink)
Ditto No Doubt, he's da man.
01 QS/Blk, A&A LS2 402 stroker w/ Vortech T-trim 723rwhp 700rwtq, RPM Tranny.
Zrod is offline   Reply With Quote
Old 11-08-2004, 05:11 PM   #9 (permalink)
NYCHASM's Avatar
Ehhh...phooey
Hey DennyM and wantazo6 and PerforminNorman...
how much you wanna bet these guys can't add without a calculator either!
Charlie
Old 11-08-2004, 05:22 PM   #10 (permalink)
I didn't claim I use a torque wrench. He asked what the specs were and those are the torque specs.
Like DennyM, wantazo6, PerforminNorman and NYCHASM I use my calibrated hands.
Old 11-08-2004, 06:24 PM   #11 (permalink)
NYCHASM's Avatar
You're absolutely correct I convicted you on circumstantial evidence. My apologies to you sir.
How great is this...to be included in the same group with you guys! A distinction I certainly don't deserve.
Charlie
Old 11-08-2004, 06:43 PM   #12 (permalink)
Originally Posted by NYCHASM
Ehhh...phooey
Charlie
Where is the "I'm with stupid" sign at??
Zman
Old 11-08-2004, 06:45 PM   #13 (permalink)
[quote=NYCHASM]Ehhh...phooey
Smart A$$ are you?
Zman
Old 11-08-2004, 08:02 PM   #14 (permalink)
Charles, I can't speak for the other fellas, but I can't add with or without a calculator. So I just follow along dragging my knuckles on the ground. It helps me keep track of stuff.
Old 11-08-2004, 08:55 PM   #15 (permalink)
Personally, I still use a slide rule.
Setting for HPDE harry kaplun Racing 12 09-22-2006 05:03 PM
torque tube to bell housing Torque spec? gmblack3 C5 Z06 - Pit Road 4 02-26-2005 04:47 PM
SERIOUS concern setting in... PowerPro01 The Garage 26 01-09-2005 02:08 PM
correct a/f setting kent menges C5 Z06 - Pit Road 19 02-21-2003 10:58 AM
Setting up cones Joslyn Racing 6 12-26-2002 07:43 PM
