Old 12-13-2003, 04:12 AM   #1 (permalink)
TPIS Oval Intake and TB vs. Stock LS6 intake and TB on a 450 RWHP 346 CID Z06.
Let's clear the air a bit on the "Magical Intake".
We had the opportunity to test it on a customer's car that came in for some updates on an older H/C package on a 346 CID Z06 and prior to the mods we decided to dyno the car with the stock LS6 intake and TB, and then with the TPIS oval inlet intake and oval TB.
Here are the results.
Both runs were made on stabilized temperatures. In other words, when a dyno run is first made on a cold drive train with low oil temperatures vs. stabilized temperatures there is always a 5-10 rwhp difference. This is why without making any tuning changes to a vehicle on the dyno, by the third or fourth run it makes 2% -3% more power than the first run if timing, A/F and coolant temperatures are kept the same, subsequent runs repeat within 1-2 hp.
The difference between the two intakes and TB was 3 ft/lbs and 6.7 hp.SAE corrected. If you look closely at the dyno graph, the two runs are within 1-3 hp all the way up to 5,000 rpm, as the engine keeps accelerating past 5,000 there is grater air demand and the TPIS intake with it's larger TB begins to make more power than the stock LS6 intake and stock TB. The TPIS intake is made by machining off the snout from a stock LS6 intake and attaching a new oval opening that excepts an oval TB, so the runners are left intact (stock length, diameter and taper angle) and won't change the wave action. This is also consistent with what we found on Brent's car (Stage 3X test car).
Sooner or later some other shops/racers will have the opportunity to test the difference between the two intakes and TBs, it would be very interesting to compare notes.
Julio
Owner of CARTEK RACING Ph# 908-317-4496
www.cartek.net
Home of the first C6 in the 10s
RIP RAY RIP ROM
tekhombre is offline   Reply With Quote
Old 12-15-2003, 01:26 PM   #2 (permalink)
Here are two runs showing the MAP (in.hg.) difference.
Stock LS6 intake and TB,--- Oval Intake and TB
RPM --+-- MAP -----+----- RPM --+-- MAP --
2976------29.8 -----------2976 -----29.8 ---
3508------29.8 -----------3490 -----29.8 ---
4046------29.5 -----------4046 -----29.5 ---
4604------29.2 -----------4601 -----29.5 ---
5226------29.2 -----------5193 -----29.2 ---
5806------28.9 -----------5781 -----29.2 ---
6354------28.9 -----------6358 -----29.2 ---
6851------28.6 -----------6862 -----28.9 ---
The sampling rate is slow with the 20 items I was logging at the time and the samples are not at the exact RPMs, but a trend can be seen.
Julio
Old 12-15-2003, 01:48 PM   #3 (permalink)
Cobra4B's Avatar
Seems like a huge waste of money. This isn't the FAST intake is it?
Old 12-15-2003, 02:15 PM   #4 (permalink)
Send a message via AIM to Stry Send a message via Yahoo to Stry
Crystal clear presentation. Thanks!
Stry
Stry is offline   Reply With Quote
Old 12-16-2003, 01:40 AM   #5 (permalink)
Cobra4B, it's not the FAST intake. This TPIS Oval intake and TB, is fine for strokers (10-15 hp) or for the person that want's that extra 6 HP out of their H/C car and doesn't care at what cost.
Julio
Old 12-16-2003, 05:10 AM   #6 (permalink)
Julio, I realize that you probably haven't had an opportunity to benchmark the FAST intake but how do you feel the TPIS will perform relative to the FAST intake on a big bore stroker?
z62jag is offline   Reply With Quote
TPIS LS6 intake w/ oval throttle body butcher Member Sales - Parts & Cars 0 03-06-2006 12:26 PM
WTB: Stock LS6 intake manifold jbuerke142 Member Sales - Parts & Cars 3 03-07-2005 11:25 PM
MTI ported stock throtle body for LS1 and LS6 intake for sale SDB Member Sales - Parts & Cars 0 02-26-2005 08:29 PM
***for Sale*** Quickest N/a 346 Cartek Stage 3 Ls6 Long Block 500 Rwhp*** brent EB02 Member Sales - Parts & Cars 7 05-20-2004 11:36 PM
WTB LS6 stock intake or cam. CalvertSS Member Sales - Parts & Cars 2 04-05-2004 05:50 PM
