Old 11-13-2001, 11:41 AM   #1 (permalink)
Traction Control ?
I took the car to Steele on Sunday, what a zoo!
I have a lot to learn about launching on the F1's, and need to make some suspension tweaks for the wheel hop.
There is one thing happening that makes no sense to me. I turn the traction control off, but as soon as the tires spin (or hop) on launch or shifting 1/2 and 2/3 it comes back on and man does it pull the car down hard??!! I turn it back off and wham it comes back on at the next shift. Despite this 12.9@113 MPH on a 2.0 60', not horrible since the car had 400 miles on it.
So is this normal (which begs the question which fuse do I have to pull to make it stay off) or something that the dealer should fix?
Les
[sold] 02 QS Z06 383 c.i.
Old 11-13-2001, 12:13 PM   #2 (permalink)
Something seems wrong here. Once you've turned TC/AH off, it should stay off until you a)press the button again, or b) start the car (which always turns both on)
Is there any chance that during a shift you're accidentally hitting the button on the console?
Jerry
'93 LT1 Coupe, Red/Tan, Auto
Jerry Velders is offline   Reply With Quote
Old 11-13-2001, 12:34 PM   #3 (permalink)
Even with the TC off, the '02 computer will try and detect and control wheelhop. WH is *terrible* for the drivetrain. This is probably to reduce warranty claim costs.
BrianK is offline   Reply With Quote
Old 11-13-2001, 01:07 PM   #4 (permalink)
I am definiately not accidently hitting the button again. The thing is that other 02 ZO6 cars that were there that day, also getting some wheel hop, and were not having the computer reingage the T/C. So while I know what to do on my F-Body for wheel hop (pan hard rod, adjustable LCA's and poly bushings) what is recommended on the ZO6?
Thanks for the help and keep the ideas coming!
Les
Old 11-13-2001, 01:37 PM   #5 (permalink)
Hold the button down for 5 seconds and put it into competitive driving mode. You will like it much better. You do not get the traction control to come on and cut the power to the wheels. If you get a little out of shape you may get active handling to kick in but it is not as intrusive as the power cut of TC. Just watch the rev limiter. Good luck!
Don
Old 11-13-2001, 02:03 PM   #6 (permalink)
Send a message via AIM to Andy Cravens Send a message via MSN to Andy Cravens Send a message via Yahoo to Andy Cravens
Yeah, Something is definatly wrong. Usually when I get in my Z06, the first thing I do is turn traction control off. If I feel that i need it, I will turn it on
Andy
02 T/R Z06
Best E.T. 12.42@116mph
Completely stock-for now
Andy Cravens is offline   Reply With Quote
Old 11-13-2001, 02:23 PM   #7 (permalink)
Send a message via ICQ to 70boss302 Send a message via Yahoo to 70boss302
I have never had traction control come back on by itself but I have had active handleing kick in a few times and wish it didn't! Maybe I don't get bad wheel hop since I run 26 psi in the rear and 28 up front. The whole car seems to co-operate better and feels more like a part of me than driving itself! BIll
70boss302 is offline   Reply With Quote
Old 11-13-2001, 06:20 PM   #8 (permalink)
Vette Doctor
c4c5specialist's Avatar
Hi there,
Idont think your TC is coming on, I think it is Torque management is kicking in.
These are different programs, and act differently. Torque management come into play when it sees high revs, clutch, and a couple of the JL4 sensors going out of range. IT is technically called abuse management also.
Normal, and it would require Competition mode, as noted by other members, or refinement of your launching technique to prohibit this program from setting in.
F car is programmed totally different, and will act accordingly. ZO6 is a different animal, and with the additional programming, you will experience different things.
Please let us know if we can help further, and yes, it is a normal condition. c4c5
Old 11-13-2001, 06:31 PM   #9 (permalink)
c4c5specialist,
Paul, COFFEE is on me anytime..................
Old 11-14-2001, 09:30 AM   #10 (permalink)
Thanks for the info. The reason I believed it was the traction control coming back on is that the LED indicator switches to "traction control on" and I have to hit the button again to turn it off. I will try to get the wheel hop fixed as well as try competition mode next time - many thanks.
Les
Originally posted by c4c5specialist
Hi there,
Old 11-14-2001, 04:22 PM   #11 (permalink)
Vette Doctor
HI again,
I tell you what, lets try this, once you turn the TC off, open your center console, and pry up underneath the switch bezel, and pop up the switch.
Unplug the switch, and see if it reactivates.
I have had 2 c5, that the switch would intermittantly come on. YOu may be number 3, so disconnect it, and we can rule this out.
Please keep us posted, c4c5hammersdiagnosin
Old 11-14-2001, 04:39 PM   #12 (permalink)
I'll do that next time at the track - thanks for the idea. FYI this only happens on hard launches and shifts at the track so I suspect your "abuse mode" theory is correct.
Les
Old 11-14-2001, 04:58 PM   #13 (permalink)
Serious wheel hop could be turning the switch back on. Great point. c4c5
Jason
01' Quicksilver Z06
Jayzvette is offline   Reply With Quote
Old 11-14-2001, 05:27 PM   #14 (permalink)
Send a message via Yahoo to pmontelo
I turn off AH & TC at the strip
I have also had many problems when running at the dragstrip in competitive mode due to wheel hop.
On one launch I even got a "Service ABS" message with a code indicating that right rear wheel speed variance was too great.
I have also experienced the system kick in several times on my 3-4 shift which is very, very annoying on an otherwise perfect run.
The solution for me is to turn off both active handling and traction control at the strip. I have never had a problem when both are off.
pmontelo is offline   Reply With Quote
Old 11-14-2001, 11:23 PM   #15 (permalink)
thx2.net's Avatar
Send a message via AIM to thx2.net Send a message via Yahoo to thx2.net
My Z is finally broken in and started to drive the hell out of it.
When merging on the freeway here in SD with crappy roads, I've noticed that if I'm driving really hard and if I hit a rough spot in the road during WOT or heavy acceleration, I lose power to the rear wheels for 1 - 2 seconds until it recovers, I usually don't let off the gas .
I'm wondering if that's the TC or AH kicking in? I've never been able to look at the DIC since I'm usually merging onto the freeway and watching for traffic when this power loss occurs.
Can anyone confirm this is what's happening?
no links to commercial sites
Click on banner for great pics, DIY Mods, jokes and other cool stuff
thx2.net is offline   Reply With Quote
Traction control beerkat C5 Z06 - Pit Road 11 12-12-2006 10:19 AM
Traction Control LethalZ C5 Z06 - Pit Road 13 06-07-2006 05:33 PM
FS: Brand new RaceLogic traction control system with launch control jimlab Member Sales - Parts & Cars 14 12-31-2005 02:51 PM
Traction Control... SomeGuy604 C5 Z06 - Pit Road 9 08-21-2005 10:34 PM
Use Traction Control or Not davidsz06 Racing 25 06-26-2004 11:13 AM
