Old 10-02-2001, 09:07 AM   #1 (permalink)
PerforminNorman's Avatar
Traction control/Active handling question!
If one has the traction control disabled but still has the active handling enabled and power shifts to second, will the active handling activate. I got into the habit of turning off traction control as soon as I start the car but leave active handling enabled. The last couple of times I have power shifted to second the car feels like it is bogging down. Today, I put the car in competitive mode and it did not bog at all.
Is it possible that active handling is sensing the rear slide and applying a brake?
Thanks for your response in advance.
Come to the Z06 Fest!
Performin' Norman
Old 10-02-2001, 09:10 AM   #2 (permalink)
Normin,
Yes the AH will still kick in if the butt gets out...........
Old 10-02-2001, 11:35 AM   #3 (permalink)
I sense some confusion on this post. Just for clarification, there are 3 modes of operation.
1. AH/TC on - All systems active - DEFAULT mode
2. AH/TC off - All systems inactive
3. AH ON - TC OFF - Competitive mode, Active Handling on and Traction Control OFF
JC
Need tires? Get em from Tirerack by clicking the ad and the forum gets 5%!
N4C5S is offline   Reply With Quote
Old 10-02-2001, 11:40 AM   #4 (permalink)
Send a message via ICQ to NetJunkie
What happens when AH engages? Make a sound? DIC pop up with a message? How long does the message stay up?
NetJunkie is offline   Reply With Quote
Old 10-02-2001, 11:50 AM   #5 (permalink)
It will say
ACTIVE HANDLING ENGAGED
(I think it's engaged) and will appear for about 5 seconds.
JC
Old 10-02-2001, 11:51 AM   #6 (permalink)
JC
I believe he's doing #3,
PerforminNorman,
Yes you should get a "Dic" blip on AH....
Lets get C4C5 in on this................................
Old 10-02-2001, 11:52 AM   #7 (permalink)
Now I'm concerned. I pulled out on to a 4 lane road the other day and must have hit gravel or something. I did a complete 270...I didn't hear or see any AH message.
I understand if I hit gravel and it engaged but didn't help, but I don't think it even engaged.
Old 10-02-2001, 11:58 AM   #8 (permalink)
It depends, if all four wheels are turning the same rate (or nearly), especially at low speed, the car might think you are intending for this to happen. I have noticed that at low speed that it will allow you to do some crazy things......Sometimes when I hit an onramp too hard and the rear gets just a little light, it will come on, when it really shouldn't.......
But, with all that aside, it will save yer life AH always on for me....TC, now thats another story
JC
Old 10-02-2001, 12:29 PM   #9 (permalink)
Thanks for the answers folks. I do appreciate it.
Old 10-03-2001, 07:05 PM   #10 (permalink)
Norman:
The AH/TC system actually can engage the rev limiter if the rear wheels are spinning. This is the hesitation you felt.
Putting the car in the comp mode will disable the TC system's ability to activate the rev limiter if wheel spin is detected. The rev limiter should still engage if a detected RPM above the set point is too high (I think it's 6500 rpm).
JC is correct, there is just AH/TC on, AH/TC off, and Comp mode: AH on TC off.
Quicksilver 01 Z06 DRM Long Tube headers, DRM Custom Roller Cam, Springs, Titanium Retainers, Chrome Moly Rods, DRM Ported CNC Heads, S/S Valves, DRM Ported Throttle Body, Donaldson Blackwing Intake, Centerforce Clutch. DRM PCM Reprogram. 402 rwhp/ 381 rwt
Dennis Jurs is offline   Reply With Quote
Service ABS/Traction Control/Active Handling? joe16649 C5 Z06 - Tuning & Electronics 16 09-25-2006 09:05 PM
Active handling / Traction control!!!!!!!! Alabama C5 Z06 - Pit Road 7 07-27-2005 05:20 AM
Traction Control, ABS and Active Handling Q? SGT. PYLE C5 Z06 - Pit Road 2 01-12-2005 01:10 PM
Active handling & traction control. How, what? MGNiko C5 Z06 - Pit Road 10 05-05-2003 08:30 AM
Discussion: Active handling/Traction Control Anil Rao C5 Z06 - Pit Road 31 05-08-2002 02:32 PM
