Old 03-29-2006, 01:31 PM   #1 (permalink)
Trailer Hitch problems
2003 Z06:
So I searched the forums, made an appointment with two different installers... same result: will not install a Draw Tite hitch on a Z06. Other models are OK, but not a Z06.
What's up with that? Any recommendations? Model numbers. I noticed Curt has a model specified for the Z06; however, it is much more expensive... which I'll do if I have to.
Thanks for any input.
BC
PuyZ06 is offline   Reply With Quote
Old 03-29-2006, 11:22 PM   #2 (permalink)
ajf
I install a DA'LAN, model #257239 on my 01 Z06. The Instructions said the application was Corvette, Coupe & Convertible, 1997 - 02. No mention of the Z06. I purchased it 2 years ago, so it might be that the instructions hadn't been updated for 03. It fit fine. The only issue was that the mufflers had to be dropped because the pipes blocked access for drilling two of the requred mounting holes. I did the wiring hookup through the holes for the tail lights.
I have a vague recollection the Draw-Tite and DA'LAN are now the same company.
01 Z06, mostly stock
05 Altima, 81 GS650G, 05 SV650s, 72 S-1S, 82 BD4
ajf is offline   Reply With Quote
Old 03-30-2006, 12:25 AM   #3 (permalink)
I went with the DaLan because a vendor said it had 250 lbs tongue weight while the DrawTite had 200 lbs. These specs were from a trailer products website.
02 black/black, B&B shorty headers w/ ceramic coating, magnaflow x pipe, blackwing, MMS programming, SLP smooth bellows, 04 shocks, stainless brake lines, Hawk HP+ pads, GiroDisc rotors, T-1 sway bars, Corvette Armour,
382.9 RWHP 366.8 RWT
Steve J. is offline   Reply With Quote
Old 03-30-2006, 04:24 AM   #4 (permalink)
There is no difference in the Z06, Coupe or Vert for the area affected by the hitch.
It's not that hard to do yourself. move the exhaust out of the way, drill 4 holes and bolt it up.
Lancer033 is offline   Reply With Quote
Old 03-30-2006, 05:26 AM   #5 (permalink)
Easy to install, just installed mine about a month ago. Took me right at an hour to install it (not including the wiring).
Chappy is offline   Reply With Quote
Old 03-30-2006, 06:10 AM   #6 (permalink)
KCMAGS's Avatar
Is there anyway I could get one of you guys to post some pics??? I'm going to be taking part in the"Hot Rod Drag Week" this summer & will need to pull a small trailer. Thanks in advance.
Old 03-30-2006, 12:29 PM   #7 (permalink)
Thanks for the info. Do you just remove the muffler retaining brackets and let them hang to install the hitch. Man, it looks tight under there. The hitch is due on-dock tomorrow in support on NWR SCCA Solo II #1 on Sunday. Crossed fingers.
Thanks again.
BC
Old 03-30-2006, 11:33 PM   #8 (permalink)
ajf
I had to split the exhaust system ahead of the rear axles to get enough clearance to drill the holes. The service manual says the gaskets are not reuseable - about $10 (converts to $8.50 US) each at the local dealer.
Old 03-31-2006, 06:48 AM   #9 (permalink)
Cobra4B's Avatar
The installers are wrong... the frame etc is all the same, a Z06 is not a different car.
Having 2-tip stingers I didn't have to move the exhaust at all. It's easy.
I love mine... people can't even see it until I point it out. I have the draw-tite. I've pulled my jetski around with it too.
I got it to pull my track trailer w/ my tires and tools.
Old 03-31-2006, 06:50 AM   #10 (permalink)
KCMAGS's Avatar
Any pics????
Old 03-31-2006, 11:33 AM   #11 (permalink)
Cobra4B's Avatar
^ no sorry. I have pics of the trailer, but that's it.
Old 03-31-2006, 12:35 PM   #12 (permalink)
Yep, extremely easy. And while I do not have pictures either it looks exactly like the little drawing on the install sheet. There is really nothing to it!
Old 03-31-2006, 03:38 PM   #13 (permalink)
Great, thanks. I'm still waiting for the brown truck to show up... it's been out for delivery since 5AM...
BC
Old 04-06-2006, 09:28 PM   #14 (permalink)
sent you an email
I have a pdf install doc from a hitch manufacturer that I will send you
2003 QS Z06 Lots of convenience mods only
2004 Silverado 5.3 -- just a truck
Miatas -- Spec Miata and SCCA STS2
NealB is offline   Reply With Quote
Old 04-11-2006, 12:42 PM   #15 (permalink)
The installation of the hitch went smoothly, thanks to the input from you all.
I'm having problems with the wiring though. I can get the signals, parking... but the brake lights aren't working. I even tried to tap into the third brake light thinking I could isolate the turn signals, but still no go. Any ideas?
Thanks,
BC
Trailer Hitch woosch C5 Z06 - Grandstand 25 10-08-2007 05:19 PM
A trailer hitch?? Zambroski C5 Z06 - Grandstand 8 01-24-2004 05:35 PM
Trailer Hitch aggie_corvette Northwest 5 10-23-2003 02:56 PM
Trailer hitch on the Z? bodale C5 Z06 - Pit Road 13 08-12-2003 06:15 PM
Trailer hitch wiring Day C5 Z06 - Pit Road 5 08-12-2003 02:32 PM
