Old 04-13-2002, 01:54 PM   #1 (permalink)
Send a message via AIM to Dash8Drvr
Trailering
HELPPPPPPPPP!!!!!!
Can't figure out the best way to tie my Z down to a trailer. It's getting delivered (the trailer) April 29th. It's a 16 foot dovetail drop axle wood deck car hauler. Any info on where to route straps, rings anything. I would like to have a plan before I pick the trailer up, so that way if I have to mod the trailer in any way, I can order the parts. Is it OK to route 3 inch wide nylon straps around the suspension arms being as they are aluminum?
ANY help would be greatly appreciated!
Dash8Drvr is offline   Reply With Quote
Old 04-13-2002, 01:58 PM   #2 (permalink)
I went through this myself lately and decided that the safest place to tie down the car was either using wheel nets or running slings through the wheels.This lets the suspension work and should not hurt anything.I was very nervous about tying down suspension parts for fear of causing damage.
abouttime is offline   Reply With Quote
Old 04-13-2002, 02:05 PM   #3 (permalink)
I tried putting the wheel nets the trailer place had on the car, they will hit all the fiberglass in the area around the wheel wells. Is it OK to put straps through the rims? If it is, that will be the easiest way to do it.
Old 04-13-2002, 02:08 PM   #4 (permalink)
DJWorm's Avatar
If you do not have adequate Wheel Nets you should use T Hooks in the factory frame slots. Using the suspension pieces my bend them or through the alignment off
Old 04-13-2002, 02:12 PM   #5 (permalink)
I assume the t hooks go in the frame holes above the mufflers in the back? Without jacking the car up, I haven't found the holes in the front. Do those interfere with the muffler when you tighten down the straps using the t hook holes? I really appreciate the help,
Old 04-13-2002, 06:02 PM   #6 (permalink)
Vette Doctor
c4c5specialist's Avatar
Hi there,
T hook locations are under the outside sills below the doors, in the frame rails.
You will find that this is the correct location.
It is the only place that shippers lash down the cars.
DO NOT, under any circumstances, lash to any suspension components.
Besttoyou, c4c5
Old 04-13-2002, 08:09 PM   #7 (permalink)
YOU ROCK!!! Havin' one for you guys!
I knew I could count on z06vette.com I never would have found those T hook locations. I never would have thought to look there!
Thanks
Trailering your Z06 ?? DJWorm Racing 5 08-14-2005 09:47 AM
Trailering the Z06 Turbine-Man C5 Z06 - Grandstand 7 02-02-2005 06:57 AM
Educate me on trailering please dmtnt The Garage 5 11-24-2004 03:07 PM
Trailering LtMash1A Racing 14 04-11-2003 10:10 PM
Help with trailering? 2K1 Z06 C5 Z06 - Grandstand 13 11-06-2002 07:45 AM
