Transzilla T-56 - Z06Vette.com - Corvette Z06 Forum
Old 01-08-2009, 08:28 PM   #1 (permalink)
GR8 WHITE's Avatar
Transzilla T-56
Does anyone have the Tranzilla transmission for their Corvette?
If so, how does it compared to other transmissions available?
It comes with a 12 Month unlimited mileage warranty.
Transzilla gearing:
Option A) 2.98 / 1.99 / 1.35 / 1-1 / .86 / .73
Option B) 2.71 / 1.79 / 1.30 / 1-1 / .89 / .75
Option C) 2.62 / 1.60 / 1.21 / 1-1 / .85 / .76
2006 C6 Z06 Gearing:
2.66 / 1.78 / 1.30 / 1.00 / .74 / .50
M12/Z06 Manual Ratios:
2.97 / 2.07 / 1.43 / 1.00 / .84 / .56
MM6/C5 Manual Ratios: MY CURRENT TRANSMISSION
With my current HP/TQ, I will punch it at a 1st gear roll, 2000 RPM
and start spinning my Yokohama Advan Sports 285 / 35/ 19 (180 Treadwear) at 4000 RPMs.
Ideas, suggestions? Will wider tread help cure the spin?
I selected Option B as it will give me a slighter edge over my current 1st and 2nd gears, but not as harsh a ramp up as Option A, but has a stronger 5th and 6th gear ratio for upper end pulls.
GR8 WHITE is online now   Reply With Quote
Old 01-09-2009, 12:24 PM   #2 (permalink)
Re: Transzilla T-56
Glenn,
There's nothing wrong with your trans. It's your clutch. I talked to Joe after he drove your car and he said there was nothing wrong with your trans. Shoot me a PM and I'll tell you what he said. Save your money on a new trans and get a better/eaiser engaging clutch.
Tony
http://www.z06vette.com/forums/f68/u...natures-84181/
Tony No car for now
Past Vettes: 02 MY Z06 554 rwhp
02 QS Z06 6XX rwhp
Z O SICK is offline   Reply With Quote
Old 01-09-2009, 02:16 PM   #3 (permalink)
GR8 WHITE's Avatar
Re: Transzilla T-56
Originally Posted by Z O SICK View Post
Glenn,
Tony
Funny you say this because I spoke with George at Tranzilla Shop and he asked what clutch I had. I told him the RPS Stage 3+ and he also said "Get rid of it". He said its idle down spin (or whatever) was not in synch with the transmission. And maybe that is why when the spin down, the gear shifts right in. I don't know.....But what confuses me, is he also said the Textralia OZ700 wasn't the best selection either. And, when I do get my next set up, I needed to stay away from an aluminum flywheel and get billet steel.
He also said it doesn't sound like my transmission either, but more the clutch set up I am running. (Spin down time with aluminum flywheel) And the funny part is, all this started right after my clutch install in Germany. But, what gets me, is this is teh SAME set up I had when I was able to shift fast. He sai dit coul dbe that the flywheel bolts weren't torqued correctly etc or maybe one or two are loose. Who knows..... But he did recommend that, with 103,000 mile son the Transmission, it wouldn't be a bad idea to have it looked at.
Old 01-14-2009, 06:56 AM   #4 (permalink)
Re: Transzilla T-56
You sure the standard C5 gearing is the same as the C6Z gearing. I'm almost positive the C6Z has even longer gearing than the standard C5.
2001 Quicksilver Z06 - TTA/PTA racecar
2008 Nissan Titan
Old 01-14-2009, 08:04 AM   #5 (permalink)
GR8 WHITE's Avatar
Re: Transzilla T-56
Cobra, I looked up a C6Z Transmission and it is the same as a C5 MN6 due to (i am assuming) the HP rating.
But it is the same. Unless the website was jacked up and posted incorrect numbers.
Old 02-02-2009, 03:47 AM   #6 (permalink)
Re: Transzilla T-56
Hi GR8 White,
I installed the Tranzilla (Parts) before 9 months ago, with the same close ratio 2.97 for the 1st.
And i heard that Tranzilla assembly OR Tranzilla parts need some special fluid (do you agree with that?), also i have a technical Q wich is:
Does the triple cone bloker rings and the original cone rings has the same SIZE ??? or not.
Because the technical guy just installed ONE cone blocker ring in the t-56 tranny.
drago is offline   Reply With Quote
Old 02-05-2009, 06:13 PM   #7 (permalink)
GR8 WHITE's Avatar
Re: Transzilla T-56
Originally Posted by drago View Post
Hi GR8 White,
Drago - I am not sure. But I thought the Corvettes had triple cone. Call Rockland and RPM to verify.
» Insurance
» Latest Auto News
BMW M5, M6 Get 575-HP Competition Package
BMW has revealed its Competition Packages for the 2014 M5 and M6
Most Watched Videos of the Week: May 12 – May 19, 2013
Each week, we recap the most popular videos from AutoGuide‘s
2014 BMW 5 Series Models Revealed
BMW has formally announced its 5 Series lineup for the 2014 model
» New Car Reviews
2014 Lexus IS 250 Review
From staid to sultry
2013 Buick Enclave Review
Sport compact sedan 2.0
» Featured Product
