Old 09-11-2005, 07:19 PM   #1 (permalink)
Tuning questions ? FRC Tom..
After attending the "Fest" this year and having FRC Tom tune my car..and with seeing/hearing all of those Fine Z's I decided to get heads. I have on the bench ready to install a new set of AFR 205's, and 30# injectors. My questions are, will I need to retune? and can I drive it until I can get it tuned? My mods until heads and injectors were: BPP Vortex, ported maf ends and ported throttle body, LS6 intake, G5X2 on 112 LSA cam, Lingenfelter Long tubes, TR55's, Magnaflow x-pipe, B&B Prt's and tuning, those mods put down 383 rwhp..what can I expect now? Many thanks! Greg
99 Nassau FRC BPP Vortex, ported MAF ends, Ported throttle body, LS6 Intake, 30# SVO injectors, G5x2-112Lsa cam, TR55 plugs, MSD wires, AFR 205's, Lingenfelter long tubes, Hurst Shifter, Magnaflow x-pipe, B&B Prt Speedway tips and tune. 418 RWHP
99NassauFRC is offline   Reply With Quote
Old 09-11-2005, 07:59 PM   #2 (permalink)
Super Moderator
FRC Tom's Avatar
Hey Greg.
You should be OK for driving around.
You already had the cam so your drivability should still be good.
Your LTFTs may have to be readjusted with the new found air with those heads. PE table might need some tweaking also for the same reason. Could go lean on you at WOT.
Are you going with larger injectors?
It is what it is
Old 09-11-2005, 08:01 PM   #3 (permalink)
Yeah Tom, I bought the SVO 30# ones, thanks for your help again
Old 09-11-2005, 08:18 PM   #4 (permalink)
Super Moderator
FRC Tom's Avatar
The flow rate needs to be changed in the VCM also.
Is there a dyno and tuner near you?
Old 09-12-2005, 05:16 AM   #5 (permalink)
Dyno's in the area but no tuner, I'll have to take to someone, that's why I am wondering if the car will be ok to drive normally without going to WOT or driving it hard.
Old 09-12-2005, 06:57 AM   #6 (permalink)
DJWorm's Avatar
LS7 heads
Just so you are aware that after the first of the year Chevy will introduce a new head for the LS1/LS6 which is based on the LS7 heads. This will have the larger intake runners and 12 degree valve angle, will accept the LS7 Intake manifold and be indexed for the smaller 4.000" bores. These will outflow a ported LS6, AFR or anything available now. It will CNC ported as well.
AMSOIL Online Store
Old 09-12-2005, 01:29 PM   #7 (permalink)
I appreciate the info on the new heads, but I have the AFR's here now, so I will go with them.
tuning questions... DPZ06 C5 Z06 - Pit Road 2 09-28-2005 07:44 PM
Some basic tuning questions RalphP C5 Z06 - Tuning & Electronics 17 01-04-2005 11:43 AM
2003 Tuning Questions 03 RED Z MAN C5 Z06 - Tuning & Electronics 1 08-30-2003 02:23 PM
Tuning with S/C Questions ??? Black_Magic C5 Z06 - Tuning & Electronics 12 05-11-2003 09:22 PM
More Tuning, More Questions GroundFighter C5 Z06 - Tuning & Electronics 21 01-03-2003 10:51 AM
