I was getting some noise from mine as well and this is what I found:
This is the right side catback:
This is the left:
This is what I found when I started checking everything:
The header bolts all are still tight.
The flange bolts that are pretty loose, I see that their are no locking washers on the nuts. They where not included in the kit. Will put those on and crank her down good with some air.
One of these clamps has slid back about 1/4". I thought we had tightened these pretty well. Damm tight is not tight enough.
I got everything adjusted and tightened down (very tight). After a few days and some fun runs down the highway on the way home. The freakin noise is back.
Those band clamps or whatever they are called SUCK!!!
I will try some different clamps, hopefully this w/e.
I rather have codes!
