Old 03-31-2004, 07:24 PM   #1 (permalink)
Urgent! My Z06's Horn Just Started Beeping??
It was just sitting locked in my garage. I ran out, opened it and stuck the key in and turned it. The horn stopped.
Any idea what's up????
"ROSSO Z"
Old 03-31-2004, 07:42 PM   #2 (permalink)
When you went out to the garage did you unlock the car with the fob or the key? Did you have the key fob in your pants pocket while you were in the house? It may seem like a dumb question but this happened to me once. While the fob was in my pocket, the panic button was accidentally pushed setting off the alarm.
NewZO6 is offline   Reply With Quote
Old 03-31-2004, 08:26 PM   #3 (permalink)
happened once for me...fob nowhere near me....code U1160 H recorded = loss of communication with left door control module...I would guess that could mean an intermittant LDCM "disconnect" caused the armed alarm system to think the left door was opened???
1986 Pacecar - Yellow, Flowmasters, Euro's, Splash Guards - sold to a nice family in KCMO area June 2006
2002 Z06 Black/Black, CAGS defeat
Owner Mods: Skip Barber 3 day competition, Sears Point
atuttavelocita is offline   Reply With Quote
Old 03-31-2004, 08:50 PM   #4 (permalink)
Same thing happened to me but it was a bit more embarassing. I was at the track sitting in the car, 6-point harness, helmet, gloves etc., on when I realized the key was in my drivers suit. As I tried to get the key out of my pocket I triggered the panic button.
Old 04-01-2004, 02:51 AM   #5 (permalink)
Old 04-01-2004, 04:53 AM   #6 (permalink)
Mine has done that 2 times. On both occasions it set a code (B2252 Key Cyllinder Switch Fault dcm-left). I am sure when you check you will find it has set a code.
Chromies, Hurst Shifter & Line Lock, Raybestos Cross Drilled & Slotted Rotors, Durastop Ceramic Pads, 180 Stat, 04 Shocks, LTPWS, LG Long Tubes, X Pipe & RT Cats, Magnecore KV85 Wires, 30#SVO Injectors, LS1Edit for CAGS, Fan Temps & Tune, Euro Headlights & PIAA 1100X.
GSMZ06 is offline   Reply With Quote
Old 04-01-2004, 06:54 AM   #7 (permalink)
Thanks guys.
I keep the key in my soft-sided brief case. I must have accidentally hit the panic button???
Thanks,
Old 04-01-2004, 04:10 PM   #8 (permalink)
A couple months ago I took a day off of school. When we came out to the car I hit the unlock button and the car started.... When I opened the door the horn started going off. It would turn off after three minutes... That same day over a 1000 reported calls to dealerships were made b/c their keyless remotes would not work. In the paper it said that possible explanations were the test bombing a couple miles north of Vegas was causing the airwaves to mess up. Never figured it out
Las Vegas
1987 Corvette C4
Buying a ZO6 when I turn 18, Less than 200 days away!
Go Fast! Energy Drink
MurcielagoR-GT is offline   Reply With Quote
Old 04-01-2004, 06:26 PM   #9 (permalink)
uh, yeah, uh, forgot, uh, me too...very likely caused by massive electromagnetic field disturbance, detected as far away as in Illinois, probably generated by secret weapon testing in Las Vegas (stealth plan by Kerry to save gasoline by randomly disabling vehicles)
Old 04-01-2004, 08:33 PM   #10 (permalink)
cbidwell's Avatar
I'm constantly setting off my GM cars(and truck) in the garage from my pocket - I have 3 fobs on my keychain !
- Carter
cbidwell is offline   Reply With Quote
Horn just started blowing by its self 22655TD C5 Z06 - Pit Road 13 07-31-2006 09:09 PM
C6 Z06 weekly productions once started george C6 Z06 - Pit Road 6 05-14-2005 03:44 PM
Started a new project, shocked at the weight of Z06 wheels! Cobra4B C5 Z06 - Grandstand 9 04-06-2004 06:52 AM
New Z06 - Getting started & Zaino? punchz06 C5 Z06 - Grandstand 11 03-03-2004 05:16 PM
Urgent Penske Double Adj Question on Z06 lundgren C5 Z06 - Pit Road 5 01-25-2004 11:02 AM
