Old 11-17-2009, 11:12 AM   #1 (permalink)
Valve Stem Seal Replacement
I was wondering if you want to replace the valve stem seals when replacing the valve springs if the heads need to be removed or if there is some special tool that you can use to remove/re-install the seals without taking the heads off. Z is a 2002' (if it matters). Thanks
Old 11-17-2009, 12:09 PM   #2 (permalink)
Re: Valve Stem Seal Replacement
They just pop off so the head does not have to come off but
to prevent valve dropping down into cylinder if you use an air compressor connected to the hole for sparkplug would keep the valve from dropping.
If not rope could be pushed into that hole filling cylinder free space so valve cannot drop so far down that you cannot get it back from the top
Else much more hassle turning engine over to keep cylinder at top so valve stays up.
Mike M - 2001 / 2008 Z06s
Old 11-17-2009, 02:31 PM   #3 (permalink)
Thanks for the info. I was aware of the need to hook up air to the spark plug hole (to prevent valve drop), but wasnt sure if there was a 'special tool' req'd for replacing the valve stem seals. Good to hear that I dont need one.....
Old 11-19-2009, 09:41 AM   #4 (permalink)
RocketSled's Avatar
IMO, the "Rope Trick" is better than compressed air. I had someone trip over a hose once, and the result was that I ended up having to peel the damn head off to retrieve the valve, and while I haven't done a lot of valve work since that happened, the few times I have I have always opted for rope over a compressor. The rope is just more "fault tolerant" a method...
C6!
Old 11-19-2009, 09:53 AM   #5 (permalink)
Ha Ha Ha....Thanks Rocket.....Man I would have "killed" the guy who tripped over the air hose.....
Old 11-19-2009, 10:13 AM   #6 (permalink)
Z0fritz's Avatar
Like the above post said, they just pop off. I do have the little plastic tool used for installing them and I like it. It only cost like $5 or $10 bucks...it makes it simple. Probably not needed, but I like having tools. I suppose you could accomplish the same thing with a deep socket or something though.
2003 Yellow Z06: Comp Cam, TI retainers, Halltech Venom, SVO 30# inj, Water/Meth injection, Katech ported TB, TB bypass, underdrive pulley, Kooks LT, BB bullet exh, No cats, RPM trans/diff 3.90, exedy twin disc, BPP shifter, dyno tuned...etc...
1969 Mach 1 big block being restored
Z0fritz is offline   Reply With Quote
Old 11-19-2009, 01:11 PM   #7 (permalink)
Hmmm....Wouldnt mind picking up one of these cheap tools to do my project. Can you PM me a link to the tool fritz??
Old 11-19-2009, 01:30 PM   #8 (permalink)
Z0fritz's Avatar
LeRox,...man I apologize. I wasn't thinking. The tool I have I got from Thunder Racing back in the LT1 days. I think the valve stem seals for the LT1 is 11/32..a touch small than the LS motors...I could be wrong about that. You might call them,or any of the shops for that matter, and see if there is a tool for the LS motors....I would assume there is. But, anything that slides over the valve and allows equal pressure on the seal should work...deep socket, small plastic tubing, etc... it doesn't take much to seat them.
Old 11-19-2009, 01:48 PM   #9 (permalink)
Z0fritz's Avatar
actually, the LT1 tool might work....The valve stem seal is 11/32 (.344") and the OD is just a touch bigger according to what I can find from parts supply places online. The LS valve stem seals appear to be .500 x 8mm (.315"). So, the LT1 tool might be slightly bigger but still might work. Just throwing it out there...if it was my car I would want to be sure.
Old 11-19-2009, 03:28 PM   #10 (permalink)
Thanks for the info. From what Ive heard/read, you dont really need a valve stem seal tool for replacement on a LS motor. Think Ill just use a deep well socket or whatever works....
Old 11-19-2009, 03:29 PM   #11 (permalink)
You do not have to go find a tool.
Use a small socket that is just about the size of seal and just light taps on it.
Old 11-19-2009, 06:34 PM   #12 (permalink)
Eddie 70's Avatar
I used a socket and tapped mine on when I changed them on my 70 swap. I did however have the heads off the car.
I have read about the rope trick but have never used it myself. I am guessing the cylinder has to be on the compression stroke to use this. Is there a certain length of rope you recommend using for this? I may have to make a new tool this weekend. I do plan on changing the valve springs at some point.
02 EB Z06 No Mods Yet
12125 miles on 11/10/07
54497 miles on 1/16/09
Bleeder valve replacement DemonZ06 Racing 8 07-21-2005 06:46 AM
Rear axle seal replacement Thomasr C5 Z06 - Pit Road 2 08-28-2004 10:02 AM
Stem Cell Research? Don Benson The Garage (non Vette related) 11 03-04-2004 08:17 PM
Valve Stem Gauges - Any Opinions? Z06neb C5 Z06 - Grandstand 5 02-17-2004 07:57 PM
Valve Stem Question Z06Y Lady C5 Z06 - Pit Road 5 11-14-2001 07:36 AM
» Latest Auto News
Furious Fuchsia Dodge Challenger Celebrates 40 Years of a Muscle-Car Icon
Dodge is once again releasing a new special edition versions of its
Chicago Preview: Nissan 370Z 40th Anniversary Edition Set for World Premiere in Chicago
Just last week we thought we’d have to wait for the New York
Chicago Preview: 2011 Infiniti M37, M56 Set for Public Debut
While the media was given a sneak peak at the all-new 2011 InfinitiĀ
» New Car Reviews
2010 Lamborghini LP560-4 Spyder Review
With Lambo's new LP560 Spyder, taming the bull has never been so easy,
2010 Nissan Pathfinder SE 4x4 Review
Nissan's rugged Pathfinder is an old-school standout
2010 Chicago Auto Show Preview
The Chicago Auto Show might not have the media hype of such events as
2010 Toyota Camry SE V6 Review
An SE trim level adds a little sport to the Camry, making living with
2010 Subaru Legacy 2.5i Premium PZEV
Subaru's 2010 Legacy gives up some of the brand's more endearing
