Originally posted by will82
I never had problems with the Vortex, but what about Vararam? How easy/hard is it to install? Also, how much better is the Vararam? The bigger opening cut into my Vortex looks OK, but not perfectly clean. If the Vararam is a little better performing and is just as safe in rainy conditions, I'd consider spending the $350 for it. Any help is appreciated!
The Vararam and the Vortex are fairly equal in performance, the Vararam may get a slight advantage while moving down the road. If I had a Vortex I would keep it. More than likely the codes are due to a leak somewhere n the joints between the filter and the TB.
The Vararam has a cleaner installed look, very OEM to those who do not know better. This is the major reason I bought one.
As to rain, you would need to get the screens on the front of the car underwater before running into trouble, which I am guessing is about the same for a Vortex.
The Vararam is not a hard install, but figuring out how to install does take some time. I have done a total of six now - my own (7 hours), 2 at the first FiveOJoe mod party (3 hours total - had help), 4 at the second FiveOJoe mod party (4 hours total - had help). This is one install that past experience clearly helps!
