Old 03-12-2004, 11:23 PM   #1 (permalink)
Send a message via AIM to WayneE
Vortech Z06 dyno numbers
I went to my friend's shop today (http://www.carolinaautomasters.com) and had him tune my Z06. He did my NA tune and also gave me the initial tune for my Vortech right after I installed it.
With his basic mail order tune, the car laid down 502hp/422tq to the wheels. After a few hours of him tweaking, my final numbers were 544hp/465tq corrected, to the wheels. :eek: My NA numbers were 388hp/375tq, so the gains are substantial
My mods are LG LTs w/cats, Halltech TRAP lower section and the Vortech. We only saw a max of 5psi on the boost gauge we used. I'm not sure what the deal was with that.
I'll post the graphs next week. Right now I'm just enjoying the new power
Camaro - Cayenne GTS - Corvette - Hayabusa - 650i 'vert
WayneE is offline   Reply With Quote
Old 03-12-2004, 11:50 PM   #2 (permalink)
do you have a cam in there? what is your compression ratio? what is your air to fuel ratio? did you upgrade ur fuel system?
the numbers are impressive.. congratrs.. how is the driveability and power?
hassan
Old 03-13-2004, 12:39 AM   #3 (permalink)
Send a message via MSN to mwascom Send a message via Yahoo to mwascom
WaynE great numbers ! :eek: :cool:
Sig by Z06nut
mwascom is offline   Reply With Quote
Old 03-13-2004, 04:53 AM   #4 (permalink)
Wingnut's Avatar
Great #'s!! Humm....I have a mailorder tune and am way too rich...since my PCM is locked maybe I'll have them unlock it and go see this guy since I'm only abut 2 1/2 hours away and let him tune mine. Thanks for posting.
Magnacharger/Longtubes/RandomTech HiFlow Cats/Vortex Rammer/
MGW Knob/Borla 2-Tip Stingers/ShanerS2 TB/OEM Z06 Wheels painted black/polished lips/ACI Hood/Exedy Hyper Single Clutch/Blower Cam/495rwhp/481rwtq/3:90's with hardened output shaft
Wingnut is offline   Reply With Quote
Old 03-13-2004, 05:04 AM   #5 (permalink)
Wow! Thats way more than I expected, to think that with my stock LS1 and 9 psi from a Vortech only put out 445/421 tq. Thats 100 more to the wheels from the LS6 with longtubes! Incredible, makes me want one now. Id have to do it right as you did with the HRE's, minutubs, clutch, and hardened output shaft though which is why I havent made the jump yet, to much $$.
Honda Civic hybrid
eviLS6 is offline   Reply With Quote
Old 03-13-2004, 06:43 AM   #6 (permalink)
evil: did your LS1 have full bolt ons? if so then the numbers are really low... and remember the difference between a 98 TA and a Z is almost 60-70 RWHP..
Old 03-13-2004, 07:07 AM   #7 (permalink)
FiveOJoe's Avatar
It was my positive thinking!! I think I guessed 540.
FiveOJoe is online now   Reply With Quote
Old 03-13-2004, 07:40 AM   #8 (permalink)
Here's a picture of the graphs... before Vortech and after (sorry it's crappy, I'll scan later):
Old 03-13-2004, 07:56 AM   #9 (permalink)
PerforminNorman's Avatar
Awesome numbers.
Old 03-13-2004, 08:01 AM   #10 (permalink)
G-Z06's Avatar
Send a message via AIM to G-Z06
wow how much is that at the flywheel ?!?!
congrats wayne!
GHOST MACHINE
F1 IDLE VIDEO/DYNO VIDEO/RACING CAMEO'S CAR
G-Z06 is offline   Reply With Quote
Old 03-13-2004, 08:02 AM   #11 (permalink)
Hrm, not sure on the flywheel HP. I guess it's around 610-620?
Old 03-13-2004, 12:41 PM   #12 (permalink)
Sweet, now you really need to get the mini tubs in.
Chromies, Hurst Shifter & Line Lock, Raybestos Cross Drilled & Slotted Rotors, Durastop Ceramic Pads, 180 Stat, 04 Shocks, LTPWS, LG Long Tubes, X Pipe & RT Cats, Magnecore KV85 Wires, 30#SVO Injectors, LS1Edit for CAGS, Fan Temps & Tune, Euro Headlights & PIAA 1100X.
GSMZ06 is offline   Reply With Quote
Old 03-13-2004, 01:09 PM   #13 (permalink)
At first with just the Vortech 9 psi kit and the superchips map provided it laid down 443/421 tq. After the mac mid length headers, thunder cam (500/500 220/218 112 lsa @.005) and LS1.edit it laid down 500rwhp/445rwtq.
Initial track times with Vortech only-a traction limited 13.1@112mph w/ 2.00 60 ft. Its funny as the Z was even better stock with less power, less weight-12.7@114mph w/2.00 60 ft.
After headers, cam, tuning-11.9@119mph w/ 1.8 60 ft. on Dunlop SP8000 315/35/ZR17's.
One thing with the Vortech is and Im sure the dyno sheet from WaynE can attest to is the power band is extremely steep. It looks good on paper, but all motor cars f-bodies/vette's putting down 500 rwhp were in the low 11's at almost 130 mph. I compared my dyno to NoMercy's dyno and he had 100 more rwhp at 3k,4k,5k, only the Vortech's peak power #'s were high. Typical with a centrifugal blower as the HP is exponential. And the tq. values are much lower than all motor as the parasitic loss from the crank draws substantial tq.
Actually WaynE's dyno looks pretty good, Id like to see the track results. My dyno was steeper, and had a lot of spikes up top.
Old 03-13-2004, 01:30 PM   #14 (permalink)
I dont see many supercharged cars peforming well in a drag strip... it is mainly due to the fact that centrfigual supercharger put down high peak numbers.. from a highway roll supercharges show thier power... thats why many use them for road racing.. what do you think wayne? how will the car perform?
Old 03-13-2004, 06:02 PM   #15 (permalink)
I don't plan to launch at a high RPM, so I'll be leaving some ET/MPH on the table. I'd like to see low 11s @ 128-130mph on drag radials. I think that the car would run well into the 10s with a set of gears and ET Streets.
The car ran 11.96@118.54 with headers/cold air, before tuning (379rwhp).
New dyno numbers for 02 Z06. 607rwhp 503rwtq. PRAY C5 Z06 - Forced Induction & Nitrous 51 04-15-2006 03:04 PM
Z06 dyno numbers GaryZ06 C6 Z06 - Pit Road 32 10-05-2005 06:32 AM
C6 Z06 dyno...Numbers inside!!! Zlicious C6 Z06 - Pit Road 45 09-24-2005 11:50 AM
100% Stock '03 Z06 Dyno Numbers GODUCKS C5 Z06 - Pit Road 14 11-05-2003 10:21 AM
New Dyno Numbers For The Z06 Reboot C5 Z06 - Pit Road 13 10-29-2002 12:31 PM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
