its probably covering a hole, i wouldn't worry about it but feel free to ask your dealer about it...its really a meaningless spot on the car, its where the bottom of your cubby is...put an exhaust plate on it if it bothers you that much....no big deal in my book
No, a hole in this location would not be normal. I just went out and checked my 03, it was new in May. No hole, no patch, no rubber compound, no nothing. Just the smooth outside of the trunk compartment. If it does turn out to be damage or a repair I'd see your dealer about it. Good Luck
Originally posted by Stry I have a new `03 with the same "patch". Not sure what it's for, but it came that way from the factory (?).
Stry
Okay take out guesses 1 and 4 above
Wasn't one of the changes in the 03's, 04's a fuel system change? Could this have been to access something they needed to get to to change something in some cars that had already been partially assembled on the line?? Just a guess? It looks like they used a die grinder to cut a hole to get to a fitting or something and then expoxyed(sp?) in a patch. Is this where the fuel tank area would be?
I have a 03 and mine is not like that. I'd have it checked out. Unless you have a extra sharp dealer you are probably wasting your time. Ping c4c5specialist I bet he can answer this mystery.
Originally posted by Stry . . . could still be #1 I suppose
Stry
I say if two cars have it it must be some type of retrofit at the factory that went on at least until some permanant changes were made on the line. Maybe a mid year change or improvement or upgrade or a safety issue that couldn't wait and had to be addressed by actually cutting into cars on the line. Maybe not so much a safety issue now that I think about it or we would have seen a recall??
