Old 05-22-2004, 10:08 PM   #1 (permalink)
jdk
Send a message via AIM to jdk
What AFR can I expect
on a stock z06 with LGM headers..I want to scale the PE ratio down a bit (leaner) before I dyno the car.. Of course I don't plan on doing anything radical until I dyno it with a wideband, I just want to know whereabouts I should be.
jdk is offline   Reply With Quote
Old 05-23-2004, 02:05 AM   #2 (permalink)
i know for NA cars 13.1 is about right..
Old 05-23-2004, 05:44 AM   #3 (permalink)
I would suggest that you work on zeroing your LTFT's. I would suspect that since you were tuned before putting the LGs on you are positive by about 8 to 10.
Old 05-23-2004, 08:57 AM   #4 (permalink)
jdk
Sorry for not being specific when I posted - I meant AFR at WOT. I've been working away at the LTFT's for awhile
Old 05-23-2004, 09:04 AM   #5 (permalink)
I'd take a guess and say you go rich.
The pcm is really tough on protecting those new material cats(2002 to 2004 model years) when they see increases in airflow through the maf..
Sometimes..you see the fuel enrichment protocol dumping fuel in with increases in airflow like headers/intakes..etc..to cool down the exhaust gases..
I think your safe running the car hard with headers..and that ls1edit will be used effectively to allow the car to run leaner..and even more powerful
JMO
Old 05-23-2004, 09:21 AM   #6 (permalink)
jdk
I've disabled all the COT protection stuff with HPtuners (cat over temp) since I'm not running cats. I've got the LTFT's locked down to around -3 to 0 in almost all acceleration conditions.
I'm just wondering if there is any "safe" figure on how much richer you go from installing headers(in an AFR sense), since I'd like to make some changes before I go to dyno in a couple of weeks.
What should I expect for this dfraze1pacnh The Garage 4 06-16-2006 02:19 PM
First Impressions - AFR 205cc heads + AFR 224/228 cam. McRat C5 Z06 - Pit Road 79 08-23-2004 04:04 PM
What #s should we realistically expect from the C6 Z? Atticus C6 Z06 - Grandstand 4 06-03-2004 01:28 AM
How much should I expect? millcoupe01 The Garage 4 09-16-2002 11:00 PM
What to expect gammara C5 Z06 - Grandstand 2 06-12-2002 02:52 PM
