Old 10-17-2005, 01:30 PM   #1 (permalink)
What differential fluid to use
Please give your advice on what the best differential fluid when I change.
Thanks
jonesde2 is offline   Reply With Quote
Old 10-17-2005, 01:35 PM   #2 (permalink)
Cave Man's Avatar
Send a message via MSN to Cave Man
Amsoil is good stuff. Just click the banner.
Marcus Aurelius
Cave Man is offline   Reply With Quote
Old 10-17-2005, 01:35 PM   #3 (permalink)
KCMAGS's Avatar
Redline synthetic 75/90 & don't forget the GM diff additive
Old 10-17-2005, 01:35 PM   #4 (permalink)
GR8 WHITE's Avatar
I went to the dealership and they turned me upside down for two quarts of 75/90 at $30 each and some limited slip at $7.99 each. I went to Aoutozone and got some Mobile 1 75/90 synthetic. Used the GM supplied limited slip. Drain old gunk out and wait a few minutes to get it all out. Then easily pour in one quart, then the limited slip, and top off with 2nd quart. If you can't do it yourself, I paid $30.00 to have mechanic do it for me. Most likely, $25.00 too much! It takes about 5 -10 minutes to do it all. No more. But sure beats getting the rear differential seal repaired! 10 minutes as compared to an entire day at $400 or more! hell, just go with 3:73 gears and get it all done at once...Hahahahahahahaha
Old 10-17-2005, 03:26 PM   #5 (permalink)
DennyM's Avatar
Amsoil with the 4 oz of limited slip going in in Nov. See Amsoil site for product number. SubDriver and DJWorm on the forum here can help you with Amsoil.
Old 10-17-2005, 03:30 PM   #6 (permalink)
Royal Purple works for me. I put it in the car late spring. Doesn't need LSD additive.
Old 10-17-2005, 08:55 PM   #7 (permalink)
Thanks for the mentions.
This is AMSOIL's best gear lube and what I use for the track:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
AMSOIL Ordering Information
AMSOIL Preferred Customer Program
Old 10-17-2005, 09:09 PM   #8 (permalink)
redline 75/90 for me.no additive needed.
gasboy is offline   Reply With Quote
Amount of Differential fluid? thebishman C5 Z06 - Grandstand 2 08-06-2006 01:16 PM
Differential Fluid Q's? SGT. PYLE C5 Z06 - Pit Road 11 10-30-2005 09:28 AM
differential fluid change? often? JeffRM C5 Z06 - Pit Road 8 04-08-2005 06:55 PM
Too Much Fluid in Differential Zeaux6 C5 Z06 - Pit Road 4 09-29-2003 10:59 AM
Color of differential fluid? XCESSIVE C5 Z06 - Pit Road 1 07-13-2003 09:47 AM
