Old 08-08-2004, 07:18 AM   #1 (permalink)
Send a message via Yahoo to R/ZO6-LS6
What Would Cause A MISFIRE
I was driving about 30mph, And my car just started missing.
It through Codes PO106, and PO300.
Any have any Ideas? can a Spark Plug Just go bad?
I only have 6400mi. on this car
AND it srarted when the odometer hit 6400mi.
How strange??????????????
Any help? I would be very Thankful
rz06Hurst Billet Plus.CAGS-Bypass,CarbonFiber Power Duct, Carbon Fiber Phantom Shifter Knob, Red Smooth ,coupler,Chome Ram-Air Intake System,Front & Rear Spoiler Reinforcements,Hood Seal, Door Seals, ZO6 Exhaust Enhancement Plate,Carbon Fiber Front Mask,Screens, Hardtop Partition, Deck Lid Liner. Bassini X-Pipe,Carbon Fiber Black-Outs, Cromies,Borla Stingers 2-Tips,
R/ZO6-LS6 is offline   Reply With Quote
Old 08-08-2004, 10:09 AM   #2 (permalink)
Rick,
P0106: Manifold Absolute Pressure (MAP) sensor signal not within predicted range for 2 seconds.
Inspect for:
- restrictions in the MAP sensor vacuum source
- MAP sensor seal missing or damaged
- vacuum hoses disconnected, lose, or incorrectly routed
- intake manifold leaks
- vacuum leaks at the throttle body
P0300: PCM determines that an emission type misfire present or determines that catalyst damaging misfire is present.
Potential causes are numerous, but include:
- restricted fuel filter
- running out of fuel
- excessive vibration from another source
A scan tool may be able to tell what cylinder is misfiring.
As for causes, they are numerous, shooting from the hip here based on things that have gone wrong for me, or I have changed:
- fouled plugs
- loose plugs wires
- all of the above for MAP problem
- stock fuel injector (I had one stick open - noted by significantly reduced gas mileage and one bank of fuel trim significantly different from the other side)
- mechanical failure inside the motor
I'd take it in and get it on a scan tool to trouble shoot.
Old 08-08-2004, 11:59 AM   #3 (permalink)
about a year ago I had that problem..
I would suggest just making sure all spark plug wires are on good...
FOr me it was the first plug wire nearest the passenger side headlamp..
Snapped it back in place and all was good again..
Good luck.
JB
Old 02-17-2005, 11:24 AM   #4 (permalink)
what is an acceptable, affordable scan tool to buy?
Will my Predator do the job? I have flickering dash & signal lights. Thanks, Larry
larryhstone is offline   Reply With Quote
Old 02-17-2005, 11:54 AM   #5 (permalink)
Zed
I used to get one... dealer said it was just fine, I didn't think so... change plugs... didn't fix it... so I started thinking maybe that is the way it is supposed to sound... then I changed the wires, what diff... no missfire and it ran .4 faster.
Zed
Chicks and Cars... what more do I need to say!
Bolt-Ons: 12.2 @ 116
Zed is offline   Reply With Quote
Maggie Misfire on DE Troy Nicks C5 Z06 - Forced Induction & Nitrous 4 10-24-2006 06:19 PM
Misfire codes... Blue Angel C5 Z06 - Pit Road 0 08-12-2005 01:09 PM
Help - Possible Misfire Issue EnzoM C5 Z06 - Pit Road 9 04-21-2004 08:00 AM
Misfire Cylinder 1 - Help Paladin C5 Z06 - Pit Road 6 09-05-2002 08:00 PM
misfire AJFZ06 C5 Z06 - Pit Road 1 06-22-2002 03:09 PM
