Old 07-13-2005, 10:15 PM   #1 (permalink)
Wheel Stud Size
My wheel studs need to be replaced from changing wheels so often. What size do I need to get? I would like to go with a set of ARP's, I think they would hold up a little better.
02 Z06 LS2 402 Stroker
New Best 10.508 @ 136 1.55 60'
67 Firebird C5R Blocked 427 LS6 Heads, th400, Dana 60
New Best 10.198 @ 131 NA
Z06Kern is offline   Reply With Quote
Old 07-13-2005, 10:30 PM   #2 (permalink)
These are the longer studs. Not stock length.
Old 07-13-2005, 11:08 PM   #3 (permalink)
If you have an early 02 with the open lugs, you simply run those without the caps. If you have a late 02, I don't know if the studs are too long for the nuts. I'm pretty sure they are tho, so you'd have to invest in the open lug nuts.
* Mike Garfias
Old 07-14-2005, 10:32 AM   #4 (permalink)
Thanks, I just ordered wheel studs and lug nuts.
DIY: Wheel stud replacement tsalva Z06Vette DIY Information 25 12-13-2007 02:25 PM
Need part #'s for wheel stud and lug nut? Falcon C5 Z06 - Pit Road 10 04-10-2005 12:36 PM
Bolt stud diameter size in seat PhilR C5 Z06 - Pit Road 1 01-31-2005 06:50 PM
broken wheel stud DRY HEAT C5 Z06 - Pit Road 6 07-24-2004 09:42 AM
Wheel Stud Replacement ZO6PILOT Racing 3 11-15-2003 05:38 PM
