Old 04-02-2004, 01:21 PM   #1 (permalink)
When changing rear gears to a 3.73 rear axle ratio does the speedo go off a small amo
When changing rear gears from 3.42 to a 3.73 rear axle ratio does the speedo go off a small amount and can the pcm be altered to compensate or is it not worth the trouble..?
Thanks in advance.
JB
Old 04-02-2004, 01:22 PM   #2 (permalink)
Zed
Thanks in advance.
JB
The speedo works fine. I think it uses the ABS sensor (or another sensor) to tell how fast it's going unlike older cars (or mustangs).
Zed
Chicks and Cars... what more do I need to say!
Bolt-Ons: 12.2 @ 116
Zed is offline   Reply With Quote
Old 04-02-2004, 02:42 PM   #3 (permalink)
Z06 WinterFest Coordinator
Kens06's Avatar
Location: Gilbert, AZ Z06 Fest II,III,IV,V WinterFest 1&2
Send a message via AIM to Kens06
JB, I've seen this in another thread here or on a different forum that says the pickup is tied into the output shaft some way?
You can change gears without reprograming but if you change tire height/circumference you have to let the pcm know for accurate speed readings!
I may be spreading gossip, but these people seemed knowledgable??
Ken
Kens06 is offline   Reply With Quote
Old 04-02-2004, 04:15 PM   #4 (permalink)
Vette Doctor
c4c5specialist's Avatar
HI there,
1.4 mph change is between the 3.42 and 3.73.
Verify by the ABS wheel speed sensors and the live plot feature on a Tech 2.
You cannot even worry about it.
Allthebest, c4c5
C6 Z06's with a 3.63 rear axle ratio IT L GO C6 Z06 - Grandstand 9 07-04-2006 08:49 AM
Autocrossing upgrade - Rear discs - Adapting to a solid axle rear end on a Syclone rominga C5 Z06 - Pit Road 14 08-21-2004 10:18 AM
Higher Ratio Rear Axle - Help Wurth/MD C5 Z06 - Pit Road 1 04-11-2003 10:32 PM
rear axle ratio.... GAGS C5 Z06 - Pit Road 3 09-25-2002 08:15 PM
What is the rear axle ratio on the Zo6??? TRZ06 C5 Z06 - Grandstand 8 07-26-2001 07:17 PM
