Where to mount my Valentine1 taking into consideration back window?
I am trying to find the best place to mount my V1 and it seems to be a tough call.
The rear window seems to be so small that the the optimal location for V1 would be right where the rear view mirror is
I'm confused
Where do you have yours mounted?
Do you use sunwisor clips or window clips?
If i have some tint on my windows, would it hurt the radar operation much?
right now I have mine a bit to the Left of my rear view mirror, but would like to hear what other folks suggest. I have the remote piece just havn't used it yet.
I have mine just to the right of the mirror,hardwired into the wire harness under the passenger's floor board. it's just below the darker area @ the top of the windshield, so you really can't even see it from outside the car. It goes on when I turn the key on. I use only the suction cups it came w/ & it has never come off as of yet. If the tint is dark, it may harm the radar!
(not a forum vendor, so admins tell me if I am out of line)
Note that there are two mounts - one for EC mirrors and one for standard. I have the EC version. It superglues in place, to the mirror bracket and not the glass. Works perfectly, and centers the unit for optimum performance.
(photo is not my car)
2002 MY/Black, Lingenfelter balanced/blueprinted/forged 346 with intercooled Maggie, blower cam, long tubes, Borlas, other stuff...499 RWHP
2006 BMW 750 LI
2007 GMC Yukon Denali XL
so far the best way to do it would be to manufacture some home made brackets and fix the radar right under the mirror or try to use suction cups to mount it as close under the mirror as possible...
AlexWS6-
the way you use your scanner seems inefficient to me, since you use only the radar for the front and because your radar sits so low it can't protect you from behind, i tried to do it the way you have it, but it's just too low...
I mounted the main unit to the left of the rear view with the suction cup mount. I use the remote head unit and installed it
where the ashtray was. I modified the foam that it was boxed in
to fit to size. There is also enough slack in the wire to pull it out and rest it in the cup holder
when on a nice high speed run. Close the ashtray cover and you would never know its in there. Plus you can not see the main unit through the tint on the windshield.
Left of the mirror and as high on the glass as I can get it, using the suction cup mounts.
Jerry
'93 LT1 Coupe, Red/Tan, Auto
Originally posted by Dr.Ron I have mine just to the right of the mirror,hardwired into the wire harness under the passenger's floor board. it's just below the darker area @ the top of the windshield, so you really can't even see it from outside the car. It goes on when I turn the key on. I use only the suction cups it came w/ & it has never come off as of yet. If the tint is dark, it may harm the radar!
What Dr. Ron said, except mine is to the left of rear view mirror and just below tint line.
Directly under the mirror, slightly offset to the left using the suction cups. I don't have the remote unit so I positioned it so I could still see the display and arrows but high enough to allow it to "see" out the rear window. Not sure if this is the optimal location but it works for me.
