Old 12-06-2004, 04:55 PM   #1 (permalink)
Wierd AH behavior with Nitto R2
Also posted on the other forum...got no response. Guess those guys don't actually drive theirs
Took my car out for some serious exercise for the first time since I put these tires on. I already knew the new tires really hook up in a straight line, but I did not know how they'd perform in the twisties. As it turns out, the car sticks extremely well and the tires have that planted DOT race rubber feel.
However, my AH (had it in comp mode) was kicking in A LOT ( 60% + of the curves I took). I leave it on because I don't want to plunge 1000 feet over a cliff due to an error, but it rarely came on with the F1 SCs, and when it did, I knew I had screwed up.
Here, the car seems to behave normally and it still kicks in. Unlike before, it's effect is not noticeable - I would not even know it intervened were it not for the DIC telling me so. Anyone else have this issue with the Nittos?
I will add for full disclosure that I installed a Sparco race seat and it was the first time for that too. Could I be more into the limits of the car and not noticing because of the seat? (since I am no longer flopping over)
TTRotary is offline   Reply With Quote
Old 12-06-2004, 05:16 PM   #2 (permalink)
Hmmmm. That's wierd. I would think the AH would kick in less often running R2s over F1s. Mine will only kick in if the car gets out of shape a bit, starts to rotate a bit which as you know, doesnt happen too easily on R2s in a corner unless you are intentionally really trying to really get the tail out. Are you sliding at all in the corners ? My AH does come on easily in the wet, or on a cold road with cold tires. But it shouldnt come if you have the grip you say, and the car keeping a line. Whatever you do, I would NOT recommend switching the AH off.
Glad you like the R2s - I too really enjoy how much they've inproved cornering stick - no comparision. Anything I have in the car that is not stuck down goes flying when I hit a corner (CD's, wallet, phone, etc) including me, I sure could use a better seat...
Maybe some of the other guys who have our tires or the experienced road race guys will have some insight as to why your AH is being so obtrusive.
'02 QS, Intercooled Magnacharger, ACI Radical Hi rise hood, Nitto R2's, Partition, mats, etc
Now what is offline   Reply With Quote
Old 12-06-2004, 05:35 PM   #3 (permalink)
The active handling is programmed with algorithms that are optimized for the stock F1 tires handling characteristics...By switching to the Nittos you effectively change how the pcm interprets what the car is actually doing...
Ex: With the stock F1's, as you approach the handling limits of the tires, to me at least, it seems that they begin to let go nice and gradual like...In doing this, the pcm rarely senses irratic or unusual attitude changes of the car...
But with the Nittos, I would bet that they grip tons better than the F1's...But, as most hi performance tires like that, the draw backs are when they let go, they usually do so without warning and in a much more pronounced way...The pcm could interpret these motions, as being at the edge of handling and in turn, attempt to make adjustments...
Just my two cents worth...
Peace...Gman
2002 Z06, Quick Silver, G5x3-114 w/Comp 918 Springs, C5R Timing Chain w/adj. Timing Gear, Halltech Ported/Polished Throttle Body, SuperMaxx LT Headers w/Hi_Flow Cats., Vara-Ram CAI, HP Tuners...348rwhp/345rwtq Stock @ 1200 miles, 366 rwhp with Headers, Mustang Dyno
Gman2002Z06 is offline   Reply With Quote
Old 12-06-2004, 06:09 PM   #4 (permalink)
I thought about the algorithms, but I never had these issues with AH on the prior car (a 200 Coupe) even when running V700 Victoracers (275 front and 315 rear on 17s) at track events.
Now What, I am not sliding in the corners. In fact, I am not even driving 9/10ths (more like 7/10ths), so this surprised me. That is what is odd. Normally, when AH intervenes, I know it without even looking at the DIC, and it ususally corresponds with me clearly screwing up and overcooking a turn, or doing some bonehead steering or throttle input . Here, the message just keeps appearing even though I can discern no real effect.
Old 12-06-2004, 06:36 PM   #5 (permalink)
Super Moderator
FRC Tom's Avatar
2001-2004 AH 2.
New and improved.
It is what it is
Old 12-06-2004, 06:45 PM   #6 (permalink)
2MchFun's Avatar
It's my understanding that it tales a few sessions for the AH to learn about new tires. I have heard that even putting a new set of GY F1 SCs requires a few driving sessions for the AH to get dialed in.
Hopefully after a few more drives your AH will learn the Nittos.
Old 12-06-2004, 06:52 PM   #7 (permalink)
That makes sense. You just made the change -- Maybe your AH thinks it's still on F1s....
Old 12-06-2004, 06:56 PM   #8 (permalink)
I am considering the same tires for my Z so I would be interested in knowing if this continues.
Tomasy is offline   Reply With Quote
Old 12-06-2004, 07:56 PM   #9 (permalink)
MikeyB's Avatar
I haven't had this issue at all after putting 1000 miles on my R2's. Just some feedback for you.
Old 12-06-2004, 08:34 PM   #10 (permalink)
No issues here on GSCS dot race in stock sizes. I believe these stick slightly better than the R2's.
Old 12-06-2004, 08:47 PM   #11 (permalink)
I do not think tires are the issue.
A/H compares intended path with actual path.
A/H does not know when your tires will lose grip (wet or dry).
I dont know what is wrong here but it is possible that you have an A/H sensor issue.
Sabot
Sabot is offline   Reply With Quote
Old 12-07-2004, 01:11 AM   #12 (permalink)
I run all Nitto R2's and have noticed less AH use then before. AH should only kick in if the tires loose traction, softer tires should loose traction less often.
The computer shouldn't care about the type of tread compound. That only affects "clamp down" factor. AH should only be kicking in if the car path is significantly different from the intended path.
Remember tire grip is a completely dynamic algorithm. It's completely relevant to the surface you are traveling across. A set of Nitto’s on ICE is not going to grip as well as a set of F1's on dry pavement. The computer must adjust based on slippage, not perceived traction.
I would bet your problem is more based on the new – larger tires. Perhaps they incorrectly balanced one tire, or maybe the alignment changed with the diameter change. My Nitto’s did not cause any of the problems you are seeing.
Good Luck.
Nocturne is offline   Reply With Quote
Old 12-07-2004, 06:06 AM   #13 (permalink)
This past Sunday was my 4th track event on the RII's and AH kicked in ALOT, whereas it didn't in the past 3. I also noticed ABS kicking in alot more. I attributed this to the tires being on their way out as far as heat cycles even though there is still plenty of tread left on them. Strange that this is happening to you the first time you really pushed them. What pressures are you running? I've found 31f/30r cold to be best.
Joe
My Garage
Old 12-07-2004, 08:15 AM   #14 (permalink)
Hello TTRotary,
You do not mention what sizes you are running, if you're using stock wheels I cannot comment.
I'm running 18" front and rear and am only seeing AH kick in when I'm hard into it exiting a turn (driving much harder than on F1's).
Arnoldir is offline   Reply With Quote
Old 12-07-2004, 11:07 AM   #15 (permalink)
Zed
That is strange!
I've been running the RII's for a long time now and no problems at all... maybe one of your ABS sensors is reading funny (AH uses that)?
Zed
Chicks and Cars... what more do I need to say!
Bolt-Ons: 12.2 @ 116
Zed is offline   Reply With Quote
Abnormal Behavior.... GR8 WHITE The Garage 5 09-24-2006 02:32 AM
Just when you think you've heard it all on outrageous behavior... snakecharmer The Garage 28 08-28-2005 04:39 PM
Shocking Behavior !! DJWorm C5 Z06 - Grandstand 13 05-03-2005 05:16 PM
Shocking Behavior !!!! TexasBlue72 The Garage 12 12-04-2003 10:53 PM
strange handling behavior Tony C5 Z06 - Grandstand 12 05-28-2003 05:31 PM
