Originally posted by Nazgul
I am running stock Z06 rims. Will a 275/40/17 fit the rim properly? Should I stick with the 265/40/17s? Is there a size difference between the two sizes or is it a matter of sidewall thickness?
I would think that they would, but I would call someone at Tirerack before I committed to do anything. They should be able to tell you for sure.
As far as the size difference compared to stock, the new tires would be 10mm wider and the side wall would be 4mm taller...not much difference.
JWz06.
