Old 05-13-2008, 07:35 AM   #1 (permalink)
will a C6Z t56 & diff work in C5Z?
I found a used T56 & diff out of a C6Z. What mods are needed to use in a C5Z?
Thanks
Jeff
virtualmiller1 is offline   Reply With Quote
Old 05-14-2008, 08:22 PM   #2 (permalink)
They should go in without modification. I'm not sure if this is the case with the 2008 Z06, but the C5Z diff is stronger than the one in the '06+'07 Z06.
Old 05-14-2008, 08:53 PM   #3 (permalink)
Re: will a C6Z T56 & diff work in C5Z?
It Should, However the gear ratios are different.
Just for clarification. The C5 Z06 and the C6 Z51 tranny is a MN12 which has the following gear ratio's.
Z06 MN12
1st Gear 2.97:1
2nd Gear 2.07:1
3rd Gear 1.43:1
4th Gear 1.00:1
5th Gear 0.84:1 C6 Z51 0.74:1
6th Gear 0.56:1
Reverse 3.28:1
IMO the MN12 is close ratio, because the gear spacing is close together. The MN6 is wide ratio because the gear spacing is farther apart. The Z06 tranny will give you quicker acceleration because the of the closer gear spacing keeps the vehicle in the power band.
MN6 (reg C5) or C6 Z06
1st Gear 2.66:1
2nd Gear 1.78:1
3rd Gear 1.30:1
4th Gear 1.00:1
5th Gear 0.74:1
6th Gear 0.50:1
Reverse 2.90:1
WTB: 3.90 or 3.73 or even 3.42 Diff extremecorvette Member Sales - Parts & Cars 3 07-28-2006 04:27 AM
WTB: 3.90 Diff MrKool Member Sales - Parts & Cars 11 02-13-2006 05:51 AM
It's here our new diff Kat C5 Z06 - Pit Road 24 02-20-2005 02:31 AM
how much of a diff. c5 vs z06? JAvery20 The Garage 6 03-28-2003 06:39 AM
How does this work? (Not Work Safe - Rated PG) McRat The Garage 9 03-27-2003 06:42 AM
