I am putting my old 408ci FMS SuperStroker in my 99 FRC within the next couple of months. I wanted to know if I needed to upgrade to Z06 springs or something stiffer in the front to offset the weight? Now I do not autocross or road race right now, but I might play a little in the future..
Z51 front spring is the same as Z06 front spring anyway, so I wouldn't sweat it. It may cause the front end to drop a little bit, just raise it back up with the adjusting bolts if you deem it necessary.
There's plenty of people with superchargers and no suspension mods - the weight added is about the same I'd say (75-100lbs overall).
I would recommend considering the T1 Suspension Kit with engineered and tuned stiffer front and rear Springs, Shocks & Bars.
This will not only take the increased weight but handle the increased power
From your Chevy Dealer, GM Parts Direct or Pace Parts:
PN 12480062 T1 Suspension Kit (incudes):
12480063 Front Spring
12480064 Rear Spring
12480065 Front Sway Bar
12480066 Rear Sway Bar
12480067 End Link (4)
12480068 F Sway Bar Bushing (2)
12480069 R Sway bar Bushing (2)
12480072 F Upper LH A-Arm
12480073 F Upper RH A-Arm
12480077 F Lower LH A-Arm
12480078 F Lower RH A-Arm
You will also need
1248oo94 T1 F Shock (2)
12480095 T1 R Shock (2)
Around $3,000
Note: the T1 A-Arms are the same as the Z06 A-Arms but have better poly graphite bushings. You can save money if you have a press by using the old Z06 A-Arms and installing new bushings instead of a whole new A-Arm assembly. However I do not know if a C5 A-Arm is the same, although I think it might be.
Poly Graphite Bushings can be obtained from Vette Brake & Products
Poly ureathane bushings squeak; Poly Graphite do not.
Poly graphite are not that stiff when compared to a Delrin or all metal bushings....those are stiff. Poly graphite still has enough softness to dampen harshness but has better memory and faster rebound to ensure more precise handling and less suspension setting wander. He's dropping in a big bore iron block for C____sake....you think that's not going to be harsh? Those big cubes, torque and weights will crush rubber bushings. Then Metal on Metal , Baby.....That's Harsh!!
Correct on the T1 A-Arm bushing material, so.....Using aftermarket poly graphite bushings would not only be cheaper but better still.....If you have access to a press.
Wow!!! $3k for the T1 suspension setup. It must be a complete road race suspension. I will have to talk to my buddy. He has the hookup from GM Parts.. I am a previous Camaro owner and all of these high prices I have to get use too. My buddy Jay call it the $400 Corvette tax..
Yes it is a road race suspension that is engineered and tuned to upgrade a C5 for SCCA T1 racing. It is commonly called a "trunk kit" in that it comes from or can be ordered as a kit from the factory and can be Dealer installed.
Of note it will improve a Z06 about 2 seconds a lap and will improve a C5 6 seconds a lap. It will be harsher but you will need the spring rates to handle the extra weight and power
Be aware that even though it comes as a kit you can buy the componants seperately. However this is not advisable as it will probably be more expensive that way and the T1 Springs and T1 Shocks must be used with the other T1 componants and will not work correctly with other componants
