Old 04-07-2005, 10:03 PM   #1 (permalink)
zo6 vs c6 mod potential
It just seems to me that the 2005 c6 with more cubic inches would have the greater mod potential and a more reliable bottom end to work with. Has this been discussed? I've been thinking about building up my zo6 but lately have been hearing about its weak bottom end. I makes sense to me to start with larger cubic inches rather than build my existing one.
What do you think?
jason31 is offline   Reply With Quote
Old 04-07-2005, 10:24 PM   #2 (permalink)
From what I've seen so far...the C6 isn't as mod friendly as the C5 is. Not sure why...you would think a H/C package on a C6 would make more power than a H/C on a C5 but, I haven't seen it happen yet. Of course, shops are still in the very early stages of modding the C6 so, I suspect that the numbers will increase in the near future.
Si vis pacem, para bellum.
Old 04-07-2005, 10:43 PM   #3 (permalink)
G-Z06's Avatar
Send a message via AIM to G-Z06
Heads/Cam C6's I have seen in 6spds have been running roughly the same as a Head/Cam Z06.
I believe Cartek had a Stage 2 Head/Cam C6 (6spd) and it made 446rwhp
My MTI Stage 2 Z06 made 452rwhp
Like Casey said, The more tuning that comes out I think tuners will have a better feel of the LS2 engine.
But I do know a modded C6 down here in Houston that can outrun a 383 Z06 vette....!!
GHOST MACHINE
F1 IDLE VIDEO/DYNO VIDEO/RACING CAMEO'S CAR
G-Z06 is offline   Reply With Quote
Old 04-07-2005, 10:48 PM   #4 (permalink)
I guess we know what our next video is gonna be...
Old 04-07-2005, 11:04 PM   #5 (permalink)
G-Z06's Avatar
Bring It!
Old 04-07-2005, 11:53 PM   #6 (permalink)
I don't think the bottom end is any stronger (could be wrong.) If you got the money you could run 9's with a C5. Anything is possible.
tckylem is offline   Reply With Quote
Old 04-08-2005, 12:20 AM   #7 (permalink)
The more you mod the less the difference. The ECU in the C5 apparently is easier to reprogram. On LS1Tech, vendor's report 550+rwhp from a 402 LS2 and 402s (4" stroke) are being offered from several sources.
From a performance standpoint, the more you mod you might as well have a '97 C5. One vendor on LS1Tech used a '99 coupe as they show vehicle (I believe they are well into the 9s).
DavidNJ is offline   Reply With Quote
Old 04-08-2005, 12:44 AM   #8 (permalink)
I don't think that the C6 has more "potential". Take your car and if you want to build it up, just do it. Don't go down the woulda', shoulda', coulda' road. If you're going to build up the whole motor, just take the 427 route and you'll be smiling. No regrets.
Old 04-08-2005, 03:30 AM   #9 (permalink)
I think you're right! This is what I will do. I will take 25 grand and replace my 2004 zo6 with everything that the 2006 zo6 will have except for the keychain. I have a really cool keychain with a flashlight.
Old 04-08-2005, 07:15 AM   #10 (permalink)
What do you think?
Jason, I saw your other post about h/c cars, and your concern for bottom end reliability. I am one of those guys who preach bottom end build up first before you do any major mods. There will "always" be the people who have 20k miles on their h/c car with no problems. My overall point here is piece of mind, money, and safety. You certainly arent modding your car to drive like granny goose. You mod your car to be able to use the power when you want to, or when you need it. Whenever you mod the top end of your Z, be it h/c, or s/c, without beefing up the bottom end, you're running a risk. It's not necessarily that the stock bottom end is weak, but when so much added power is placed on it, it carries the burdon of supporting all that extra power. Under certain conditions, something will malfunction. It's like putting 500lbs on a cart with inflatable wheels that were designed to handle 350lbs. You can roll the 500# around on it from point A to B for a while. But it's going to break sometime before it should.
When the situation arrises, when you want your power the most, you are going to want to harness it, and get it to the road with confidence that it wont break.
Cubic inches are always welcomed but there again so it an iron block. And here comes the bottom end issue again. And the Clutch issue. There are so many routes you can take for more power. You have to ask yourself what you want the car to accomplish. Once you have that in mind, do the mod. But as with anything you do in life, do it right the first time.
nutbush is offline   Reply With Quote
Old 04-08-2005, 07:23 AM   #11 (permalink)
Send a message via AIM to niphilli
Basically an LS2 is an LS6 with more compression and a bigger bore. So the answer to your question is YES the LS2 does have the potential to make more power than an LS6 (especially area under the curves).
I think the things you are seeing holding back the LS2 are programming and intake manifold.
I like Cars
niphilli is offline   Reply With Quote
Old 04-08-2005, 07:34 AM   #12 (permalink)
I was under the impression that the LS2 intake was an improvment over the LS6 intake...
Steve Tillman
45 Years Of Corvette Experience
Y2K NBM 6MT HP?\TQ?
It's stock they all sound like that
Steve Tillman is offline   Reply With Quote
Old 04-08-2005, 09:42 AM   #13 (permalink)
There have been some very good posts with dyno results that show otherwise...
Check out www.gearchatter.com
Old 04-08-2005, 09:51 AM   #14 (permalink)
Cobra4B's Avatar
Higher compression and larger displacement = more power potential. The bottom end isn't any "better" in reguards to strength. They're tuning is has been really held back b/c LS2-edit is finally comming out and reaching the tuners.
Old 04-08-2005, 12:07 PM   #15 (permalink)
As a starting point the LS2 is better than the LS6
FS: 2004 ZO6 Machine Silver/Mod Red OCD Member Sales - Parts & Cars 23 07-22-2006 10:44 PM
Picked up my '01 TR/Mod Red ZO6 NastyC5 C5 Z06 - Grandstand 25 03-20-2006 08:03 PM
F.S ZO6 Mod Red seats HP-JNKIE Member Sales - Parts & Cars 7 08-12-2004 06:36 PM
get a ZO6 or mod an LS1? Xtreme 4pt3 C5 Z06 - Grandstand 6 11-04-2002 04:33 PM
02 ZO6 with mod red ZOSICK6 Ross Downing Chevrolet 3 09-25-2001 10:27 PM
