So I flew into town last night and went up to Antivenom this morning to witness the dyno tuning of the car.
On the second run, at the end of the run, after Greg lifted off the accelerator, and depressed the clutch to put the car into neutral, we here a loud rattle from under the hood.
The immeadiate thought is that we broke a valve spring. We had intentionally put a lighter set of valve springs in to help break in the cam and the engine while on the dyno, and had a heavier set of valve springs waiting to be installed as the permanent springs.
Unfortuanately, when we opened her up, we found that the springs were fine, and that one of the valves in the LS7 heads had broken. The good news is that this did not happen while the car was under load, but when the car was "coasting" on the dyno.
Greg and Casey are taking her apart right now to survey the damage.
The net-net is that I will not be at the Fest until Wednesday, best case.
Parts will be ordered on Monday for overnight delivery on Tuesday, put her back together and tune on Tuesday/Wednesday, and hopefully I can head north late Wednesday.
There is the possibility that I will not be there til sometime on Thursday, which would mean missing the MM run on Thursday morning.
I will keep everyone informed as more information becomes available.
Hated hearing that Mark! You'll get her back together in time. How about moving the MM run to Saturday morning, just in case you are late getting to BG,,,,,hell, we can't break tradition and not have you leading the pack! Just a suggestion to consider.
Jimbo
Just in case things do not go as planned, I have already booked a flight into Nashville for Wednesday Afternoon. I will make the call on Tuesday night whether I will be driving or flying to the Fest, but I will be there...
Sorry you are dealing w/ all of this last minute crap. We definitely know the feeling. Hopefully yall get her up and running and you and the Orange Krush make your appearance at the fest and lead our MM cruise! See you soon!
good luck with getting your motor repaired.
i thought light break in springs were only used with flat tappet camshafts.
YOUR RIGHT!!! WHY N THE **edit** WOULD YOU PUT A LIGHT SET OF SPRINGS ON A SOLID ROLLER????
YOU DON'T DO THAT, ONLY IF YOU DON'T KNOW WHAT YOUR DOING.."BUSH LEGUE MECHANICS..PLAIN AND SIMPLE..
THE REAL TRUTH HERE IS HE DOSE'NT HAVE "PETE INCAUDO" TO CALL AND ASK HIS USUAL PANICKING "WHAT DO I DO, WHAT DO I DO??" QUESTIONS!!..
NOW ALL YOUR GONNA GET IS LAME A$$ EXCUSES FRM HIM..LIKE "WELL THA CAR WAS'NT UNDER LOAD WHEN IT HAPPENED"..GIVE ME A BREAK..LIKE I SAID, "BUSH LEAGUE" MECHANICS...
WAKE UP GUYS..
Andy
SIG by the BIGGEST, BADDEST MOFO with a broken down ride - GR8 WHITE
Reason: Next profanity gets you a vacation
