Go Back   Z06Vette.com - Corvette Z06 Forum > General > Employment
Old 03-26-2003, 02:16 PM   #1 (permalink)
Several Openings in Fairfax, VA
Great company. I am the controller. Call Sharon at 703-279-6141, if interested. Tell her the Corvette guy sent you.
Junior Software Engineers
Full-time
Travel: Required – domestic & international
Job Location – Fairfax, VA
****The candidate MUST possess a current Top Secret Security Clearance/Current SSBI****
Web oriented positions: The candidate must have a minimum of 1-3 years experience in the design and implementation of software to include web-based systems. Background should include:
Web Portals, HTML, XML, JAVA, JavaScript, C, Shell scripts, PERL, Relational Databases (SQL), and Java Server Pages (JSP). Must be experienced working in a UNIX/LINUX environment.
Signal processing oriented positions: The candidate must have a minimum of 1-3 years experience in the design and implementation of software for real-time digital signal processing systems. Experience in all aspects of code design, implementation, testing, analysis, debugging. Understating of Configuration Management practices. Languages used include Fortran, C, C++. Packages include X-Midas, MatLab (experience desired). Operating systems include VMS, Digital Unix, Solaris, Linux, and Windows.
Education Required: Candidate must possess a Bachelor's of Science or equivalent work experience (at least 3 years of software design, implementation and integration in the areas of object oriented software applications).
Mid-level Software Engineers
Full-time
Web oriented positions: The candidate must have a minimum of 4-10 years experience in the design and implementation of software to include web-based systems. Background should include: Web Portals, HTML, XML, JAVA, JavaScript, C, Shell scripts, PERL, Relational Databases (SQL), and Java Server Pages (JSP). Must be experienced working in a UNIX/LINUX environment.
Signal processing oriented positions: The candidate must have a minimum of 4-10 years experience in the design and implementation of software for real-time digital signal processing systems. Experience in all aspects of code design, implementation, testing, analysis, debugging. Understating of Configuration Management practices. Languages used include Fortran, C, C++. Packages include X-Midas, MatLab (experience highly desired). Operating systems include VMS, Digital Unix, Solaris, Linux, and Windows.
Education Required: Candidate must possess a Bachelor's of Science or equivalent work experience (5+ years of software design, implementation and integration in the areas of object oriented software applications)
Sr.-level Software Engineers –
Full-time
Web oriented position: The candidate must have a minimum of 10+ years experience in the design and implementation of software and systems engineering to include web-based implementations and network programming in a technical or scientific application environment. Background should include: Web Portals, HTML, XML, JAVA, JavaScript, C, Shell scripts, PERL, Relational Databases (SQL), and Java Server Pages (JSP). Must be experienced working in a UNIX/LINUX environment.
Signal processing oriented position: The candidate must have a minimum of 10+ years experience in the design and implementation of software for real-time digital signal processing systems. Experience in all aspects of code design, implementation, testing, analysis, debugging. Understating of Configuration Management practices. Languages used include Fortran, C, C++. Packages include X-Midas, MatLab. Operating systems include VMS, Digital Unix, Solaris, Linux, and Windows.
Education Required: Candidate must possess a Bachelor's of Science or equivalent work experience (12+ years of software design, implementation and integration in the areas of object oriented software applications)
DSP System Engineer –
Full-time
Education: Bachelor of Science/Engineering required, advanced degree desirable
This position will be responsible for the development, analysis, and evaluation of digital signal processing systems applied to SIGINT applications. This position requires practical experience in algorithm development including coding and debugging, in languages including Fortran, C, and Java. Experience with the MIDAS development environment is a strong plus.
Integration and Test (I&T) Engineer –
Full-time
Education: Bachelor of Science/Engineering or equivalent experience required, advanced degree desirable
This position will be responsible for the factory integration and test of software based signal processing systems and their subsequent delivery, installation, test, and acceptance at customer sites. This position requires practical experience in X-MIDAS hardware, digital and analog hardware, system cabling, system hardware integration, military drawing requirements and CAD applications. The ideal candidate has experience in network based system integration in a VMS and UNIX environment.
The candidate should have attention to detail, be self-motivated, and be comfortable working without supervision in a dynamic team environment.
Sr. Tech Writer/Trainer
Full-time
This position involves technical writing, editing & training of material for operators and maintainers of sophisticated, software based, signal processing systems. The candidate will be required to gather and communicate technical information verbally, in hardcopy, and online to system users. This requires the ability to work with engineers and software developers in developing the material and the ability to convey this information to the system operators and maintenance staff. Must have 10+ yrs experience in the following:
à Research and analysis of technical engineering data
à Technical writing and editing
à Proficient use of MS Office Applications, specifically MS Word & MS PowerPoint
Familiarity with digital signal processing systems, signal collection operations, and experience in web/on-line training and documentation is desired.
"ROSSO Z"
Old 05-06-2003, 06:28 PM   #2 (permalink)
ttt
Old 05-06-2003, 07:24 PM   #3 (permalink)
wvphoto's Avatar
i have a digital camera
do i qualify ?
LOL
good luck..nice to see someone is hiring !
***i need a life**********
FEAR THE MIATA
wvphoto is online now   Reply With Quote
Old 05-07-2003, 10:05 PM   #4 (permalink)
Super Moderator
mdickie's Avatar
Send a message via AIM to mdickie Send a message via MSN to mdickie
I am moving to FLA next year, otherwise I would apply for my clearance and go for it... (the tech writer/trainer position)
Mark
"Civilized until it is time not to be civilized"
mdickie is offline   Reply With Quote
Old 06-13-2003, 06:44 PM   #5 (permalink)
ttt
Some are still open...................
Old 08-10-2003, 06:11 PM   #6 (permalink)
ttt
Old 08-25-2003, 06:51 PM   #7 (permalink)
ttt
Old 10-02-2003, 06:59 PM   #8 (permalink)
ttt
Old 11-06-2003, 06:54 AM   #9 (permalink)
ttt
Not sure what is still available, but we are hiring in those general categories............
Call us..........
Old 11-18-2003, 10:51 AM   #10 (permalink)
Send a message via AIM to Sailing2Smth
Rosso
Is your company still hiring for the Sr. Technical Writer position? If so, I would like to apply for it, I do have a TS clearance, current SSBI.
Sailing2Smth is offline   Reply With Quote
Old 11-26-2003, 11:01 AM   #11 (permalink)
Sailing,
Check for a PM from me.
Old 02-11-2004, 06:07 PM   #12 (permalink)
ttt
We still have openings and we are starting to do job fairs at some universities, so the security clearance may not be a prerequisite.
You will have to qualify for one after employment.
If you are any kind of SW Engineer, call Sharon at 703-279-6141.
Great company............
Old 02-11-2004, 06:37 PM   #13 (permalink)
Golffox's Avatar
My government clearance is a secret.
Powered by ANTIVENOM
Golffox is offline   Reply With Quote
Old 03-31-2004, 08:10 AM   #14 (permalink)
ttttttttttttttttttttttttttttttttttt
Job Openings at StopTech, Torrance CA J Ritt Employment 4 09-30-2006 07:46 AM
Job Openings in Fairfax, VA. ROSSO Z Employment 0 09-28-2006 10:00 AM
Anyone here from Fairfax, VA? DigitalDisaster The Garage 1 03-10-2005 06:07 AM
Openings for VIR DE, Dec 4 and 5... ROSSO Z Racing 0 11-05-2004 10:45 AM
Oct 18 & 19 DE Event Openings.. ROSSO Z C5 Z06 - Grandstand 1 10-07-2004 10:23 AM
