Old 03-02-2008, 09:48 AM   #1 (permalink)
Send a message via MSN to Blue Blood
02 Sensor swap??
The front 02 Sensor of my '02 Z is throwing the code P0133:
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
My question is can I swap my unused rear sensors into the front without re-tuning the car? My car is running a custom tune with the rears removed, for LG LT's.
Thanks,
Clint
Blue Blood is offline   Reply With Quote
Old 03-03-2008, 11:03 AM   #2 (permalink)
Re: 02 Sensor swap??
From my experience, using the rear 02 sensors in the front locations will be fine. The only thing is that the wire for the rear 02 sensors is longer, so you will have to use some zip-ties or something to secure the extra wire length and keep it off the hot stuff (i.e. headers). Sensor itself is identical in design. Good luck....
Old 03-15-2008, 03:27 PM   #3 (permalink)
You can do this, but you'll need an adaptor since the electrical plugs do not match. There have been a few postings from others that state that the rear sensors have not functioned well, and that the final solution was new front-type sensors with extensions to reach the header bung location. Others found success by opening up the 'vent' holes in the rear sensors.
Originally Posted by Blue Blood View Post
The front 02 Sensor of my '02 Z is throwing the code P0133: P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
Thanks,
Clint
Best regards,
Bill
2003 Quicksilver roadster, 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe, wheels & air lid, Euro 90/130 watt headlights & red/clear tails, Homelink, CLB, and HP Tuners s/w - available to any 2003 in Calgary
Billf6531 is offline   Reply With Quote
Old 03-15-2008, 06:20 PM   #4 (permalink)
Thanks,
Clint
Are you sure this has not already been done seeing how you have LGM Longtubes?
You should have some wires in the box the headers came in, to extend the
o2's
2. No Header wrap needed on stainless. It dissipates heat much better than mild steel.
3.Yes use GM LS1 gaskets (#12558573)
Header to head bolts are 2 pass. USE ANTI-SIEZE
First pass is 11 lb. Ft.
Second pass is 18 lb. Ft.
AIR pipe to exhaust manifold 15 lb. Ft.
2) Gm#12553617 air tube gkts.
hpipe to catback gaskets (2x GMPN 10276792)
12558573 gaskets GM LS1 gaskets (#12558573)
ls1howto.com
Thermo-Tec hi-temp tape
Instructions posted by Lou:
The driver side header goes in from the bottom. Remove old exhaust system back to the 2 bolt muffler flanges in front of the differential. To do this, remove the spark plugs and ground strap on the driver side and install them from the bottom.
Use only stock GM- LS1 exhaust gaskets, NOT LS6 gaskets. Install all bolts finger tight in the header flange at the head. Be very careful to not cross thread the header bolts. You can install the passenger side from the bottom or top. If you go from the bottom, you might have to pry the engine over a little to make room for one flange that gets in the way. Or you can install the passenger side from the top but you will have to remove the coil packs and valve cover to install them from the top after removing the coil pack and valve cover on that side. We have done it both ways with equal success.
Do not tighten the bolts on the flange all the way until you get the bell housing bolts started. Once they are started, then you can tighten the exhaust flange on the engine.
If you have the hand made version, you should install the off road pipes or Cats with the V flange now. Some times we put a small amount of “Ultra Copper Silicon” on the V flange at the end of the collectors to insure that no air leaks into the header.
If you have the LG Pro Long Tube headers, install the slip fit X pipe using 2 of the supplied clamps. The clamp bolts should face outward at the front of the X pipe, and inward at the rear of the x pipe. >>> A leak here will confuse the O2 sensor and make the car run rich. <<<
Then continue to install the remainder of the system back to the mufflers. Keep the threaded parts of the clamps up out of harms way when they are tight for ground clearance.
After the engine is run, all bolts and clamps should be re tightened. Or we sometimes tap the pipes to vibrate the system to get the clamps totally tight.
O2 sensors:
This is very important. When you remove your old headers, you will remove all four 02 sensors. Set the old front sensors aside and do not use them, the wires are too short
Install the 02 simulators and plug them into the car harness, where the rear 02 sensors were attached to the wiring harness. The car harness has a square plug and so does the 02 simulator.
Next, take the original REAR 02 Sensors, and plug the LGM adapter into them. That will give you a long wire, with the LGM adapter which will allow this 02 sensor to be used as your main front 02sensor. Install the long 02 sensors in the collectors of the new LG headers, and make sure to route them away from any hot tubes. You must install the 02 wires one side at a time to not mix them up. The sensor on the right header (collector) gets plugged into the right side (Passenger side) and the one on the left collector gets routed to the left side plug in the car harness.
It is important that the 02 sensors go to the correct side of the car. If the 02 sensors are not hooked up correctly, the car will not idle correctly. This should be the first thing you check if a problem arises after the install. Just hook the driver’s side 02 to the driver’s side wiring harness, and do the same on the passenger side. Our 02 sensors angle across and can easily be confused. We drill a 1” hole in the upper heat shield to help route the wires, but this is not mandatory. But extra care must be taken to avoid the hot pipes so not to melt the wires.
As to your problems, you need the driver’s side back 02 sensor (with the adapter attached) plugged into the driver side front hook up. Do the same for the passenger side. The SIMs go into the plugs for the back 02 sensors on both sides. I would also pull the battery to reset the computer and then see if you get the check engine light. If you still do you need to pull the codes and define what you are getting.
Here is how and what they mean.
Please call us if you have any install questions. 972-272-7753
Hope this makes your job easier.
Also be sure to keep the 02 sims away from the headers. While they are heat resistant, too much and they will not work.
Speaking of Dipsticks...
Tip: before trying to wiggle out the dipstick, especially for a first timer, remove the dipstick from the tube first. I was pushing in and out to get that darn tube out, I didn't realize the tip of the stick hangs past the tube and bent and twisted it up like a pretzel. I tried to straighten it out.
Rocker Arm Swap with H/C swap whyw802Z06 C5 Z06 - Pit Road 2 06-03-2005 07:48 PM
What did pay for your cam swap??? Gman2002Z06 C5 Z06 - Pit Road 16 09-24-2004 05:35 PM
MAF Sensor Swap GreggHammer C5 Z06 - Pit Road 4 08-14-2003 01:32 AM
My 4.10's for your 3.42's SWAP Social_Engineer Member Sales - Parts & Cars 10 06-04-2003 07:46 AM
01 after Cam swap 2charmed C5 Z06 - Pit Road 20 10-23-2002 05:23 PM
