50 hp tune
I've been reading tuning literature on my quest to master HP Tuners on my ride. Finding some interesting stuff. I'm no expert, and glossing over topics I've read, I thought some of you might find this stuff interesting too.
Cars from the factory are of course, safe tuned. No two motors are identical, and neither are each of your 8 cylinders!
Not only can stock tune motors be tuned much better to the individual motor, but how bout tuning to the indiviudal cylinders! Individual cylinder calibration on a high output chevy v8 is good for 50 unclaimed horsepower.
Computer controlled individual cylinder adjustable electronic port fuel injection. (that's a long name!)
Each cylinder can vary enough that stock tuning safely around/at the worst cylinder leaves the others vastly unproductive.
Whatever the volumetric efficiency of each single-cylinder-engine, optimal timing and mixture can be provided.
EFI and computers make this an intellectual task. Is it real? Is it worth it? Would anyone ever do this? Check this out.
NASCAR engines are restricted to single point carburators. They actually cylinder tune the hard way by manipulating each cylinder's compression ratio, rocker arm, and cam lobe to achieve peak power from each cylinder!
850HP MTI STS 402 Twin Turbo Z06
