Re: Abs, Traction Control Out
It could be a short in the wires that run underneath the car. I had a belt break and had the service ABS/Traction Control among others that flashed across the display. When the belt broke it pulled the brown and green wire for the traction control out of the black plastic tubular housing and broke them in half. I re-routed the wires, re-connected them, and reset the computer. Problem fixed. If you have ramps you can look under the car to make sure something on the road hasn't snagged the wires.
02' Z06 EB/EB 4,400 miles, Longtubes, Off-road X-pipe, Pypes X-back, Blackwing CAI, Comp. Cam 238/240-.605/.609-112LSA, Comp. Beehive Springs, Comp. Titanium Retainers, Comp. Hardened Perf. Push Rods, Comp. Billet Double Roller Timing Chain, Hurst Short Throw, Cray 19"/20" w/ Toyo Proxes4 265/30/19's & 295/30/20's
