Removal Procedure
1. Turn the ignition switch to the OFF position.
2. Disconnect the E13CM harness connector.
3. Remove the two insulator nuts.
4. Lift the EBCM/BPMV out of the bracket high enough to
allow clearance to remove the insulator mounting bolt and
the EBCM.
5. Remove the insulator mounting bolt from the EBCM.
6. Remove the four EBCM to BPMV bolts.
7. Separate the EBCM from the BPMV by gently pulling apart
until
separated.
8. Carefully remove the seal.
The seal may by reused if it is not cut or damaged.
Installation Procedure
1. Clean the BPMV seal surface with alcohol using a clean
rag.
2. Install the seal to the BPMV if it is not cut or damaged.
3. Install the EBCM to the BPMV.
4. Tighten the four mounting bolts in the following equence:
- First pass to 27 inch Ibs.
- Second pass to 53 inch Ibs.
Important: If the insulator nut was removed it must be replaced with a new insulator nut.
5. Install the front EBCM insulator mounting bolt. Tighten
the bolt to 10 ft. Ibs.
6. Install the EBCM/BPMV into the bracket.
7. Install the two insulator nuts. Tighten the two insulator
nuts to 89 inch Ibs.
8. Connect the EBCM harness connector. Important: Both
sides of the EBCM harness connector must be engaged
with lever before closing.
9. Turn the ignition switch to the ON position; do NOT start
the engine.
10. Perform the Diagnostic System Check - ABS.
