Old 03-10-2008, 09:11 PM   #1 (permalink)
ALARM Ghost HELP!!!
I have a 99 frc with the factory alarm. I am using the factory fob. The fob training recognizes the fob. The fob seems to work fine at first but all by it’s self it then opens arms and locks it’s self and then it will open its self and locks back again. I purchased a new fob (now for sale) and it's still acting up.
Ideas???
Cornfed is offline   Reply With Quote
Old 03-10-2008, 09:56 PM   #2 (permalink)
GR8 WHITE's Avatar
Re: ALARM Ghost HELP!!!
Ideas???
Aaron - I sthere a FOB nearby that is sticking? Maybe it is picking that up. Di dyou try this elsewhere, like at a local supermarket, etc, somewhere that is far away from the house.....
Maybe try pulling the fuse for the alarm, leave out for 5 minutes, and resetting the fob.
Other than that, park it 4 doors down and dont worry about it. Hahahahaha
Let us know what the culprit is.....
Might even be a stuck door switch on the door panel? Try messing with the door panels on both sides to see if they all work.
Old 03-11-2008, 08:44 AM   #3 (permalink)
Were is the door switch on the door? I looked last night but did not locate.
I was at a frends house when it started acting up so I think it's in the system somehow..
Old 03-11-2008, 09:11 AM   #4 (permalink)
GR8 WHITE's Avatar
Aaron - I was referring to the door push buttons, to lock, unlock etc. It is possible one is sticking, which is triggering a contact "as if" someone is trying to open the doors. Its just a shot in the dark. Try removing the door window/lock unlock control panel and check for corrosion, dirt, etc.
Otherwise, I would pull a fuse and try and reset it. I will look up teh alarm later on for you, ok?
G
Old 03-11-2008, 09:18 AM   #5 (permalink)
10-4
Thanks Buddy
Ghost Car Ad - Have You Seen This? vant The Garage 11 09-21-2005 07:41 AM
Ghost Recon 2 (PS2) pauln64 The Garage 16 01-08-2005 10:19 AM
Ghost flames or no ghost flames? zoh6prncss The Garage 27 04-16-2004 06:33 AM
Ghost in the Machine Dr.Electron C5 Z06 - Grandstand 7 04-30-2003 02:44 PM
Chp Ghost Car quikdoc C5 Z06 - Grandstand 31 06-28-2002 12:56 PM
