Originally Posted by Scott Briggs
i am making mods (headers,cam,tune,high flow cats,exhaust,induction)and wanted to find out what stock rear gear is currently and also if i should inquire about taking some gear out for better launches threw 1st and 2nd now having more power any suggestions?
Scott,
I'm not sure what you are after here ? You probably have a 342 stock gear right now.. if it hasn't been changed. IMO...if you are to remain on the street I would stay right there. A 373 might start to give you way too much wheel spin on street tires. Drag radials are a little better but generally need to be heated up to really get any more performance from them on the street or track.
Now if your talking about the 1/4 mile track..that is a whole new ball game. Some like the 410, some the 390 and still some prefer the 373. Guess it would all depend on how far you are planning to go with rwhp. I personally thought the stock 342 was a lot of fun at the track...my 390 takes a lot more skill and practice to launch and get thru first gear without spin. On the street..the first 2 gears are useless and dangerous as hell. I actually hit it one day in second gear about 20 mph...tires were spinning .....then they grabbed and shot me right off the road in a ditch area..I barely pulled it out before I crashed, then bounced back up on the road. It happened so fast I wasn't even freaked out. Thought I was a pretty good driver till that day..it showed me anything can happen under the right conditions.
Good luck...don't know if that helps you any or not.
Pit
2003 Z06 - 1.48 sixty foot , 383 Stroker NA, AFR 225's, Fast, Vararam, LG Longs, 390 Gear, thru stock mufflers. Best eighth 7.14, Best quarter 11.122 @ 125.49, 2800 DA & 83 degrees
