Is Calif PCM programmed differently than other states?
Is a Calif ZO6 PCM programmed different with their 91 octane fuel & stricter emissions? I am now in VA where it is 93 octane. Doesn't seem to pull as hard as I expected.
If it is different there which way should I go with a/f & timing to take advantage of the cars new environment. I'm thinking about getting a Predator for some slight edits if that would be helpful.
I probably will not be doing any major mods for quite some time and will wait till then for a LS1 edit.
What do you suggest.
2002 ZO6 MY
1969 Dodge GTS
1972 Cuda
1970 Superbee
2-1987 Buick GN's
