Re: code help
It could also be due to an exhaust leak close to the O2 sensor.
In addition have you used any silicone sealants anywhere on/in the engine lately? That will contaminate the O2 sensors and result in that code as well. If you ever do make sure they are marked as "sensor safe" or for use with 02 sensors.
According to Lou there have been some problems with O2 sensors being fouled immediately after header installation due to left over oil inside the tubes that is used in the manufacturing process. This may explain your problem if an exhaust leak or external damage to the O2 sensor wires is not the problem.
Talk to Bobby at LG and he will get you straight.
