Old 09-17-2007, 02:01 PM   #1 (permalink)
Display unit
Hi,
Does anyone have problems with the computer display intermittantly giving false readings?
My oil is OK and recently changed, but I'm getting a low oil level alert. I also recently had a traction alert that went away when I started the car. It is a 2001 with low miles.
Thanks.
Stevie Z
Stevie Z is offline   Reply With Quote
Old 09-17-2007, 04:36 PM   #2 (permalink)
RocketSled's Avatar
Re: Display unit
Intermittent alerts are not uncommon, and they can usually be ignored if they aren't unreasonably obtrusive. But they can be a sign of a real problem.
There is an oil-level sensor that tells the PCM how much oil there is in the crankcase just before you start the engine. That sensor could be failing, or the connection to it could be dirty/corroded.
There are many possible sources for a TC fault; wheel sensors, connectors, EBCM. The DIC will give you a specific code and that might help narrow your troubleshooting focus. You should put the DIC in diagnostic mode and read out the codes. Search the forum for instructions if you don't know how to do this. "DIC diagnostic" will probably work as a search term.
C6!
On Display zman C6 Z06 - Grandstand 10 09-24-2006 03:35 AM
LED Display. rsherrard C5 Z06 - Grandstand 0 12-02-2004 04:20 PM
C6 On Display This Weekend 21STCENTURYMUSC Southwest 0 05-13-2004 08:09 AM
WTB: Heads up Display (HUD) unit John Youngblood Member Sales - Parts & Cars 0 10-20-2003 09:22 AM
Position of V1 Concealed Display unit? gmblack3 C5 Z06 - Grandstand 5 09-29-2001 11:48 PM
