Old 10-21-2007, 06:19 PM   #1 (permalink)
Drivers window will not go up
Hello everyone -
For some reason, I started my car and all of a sudden I get the TC light, active handling, and reducing engine power running across the DIC. The car was idling as I just started it and did not even drive it. I had my window down and now it will not go up. I do not have the codes on me (Which I know will help) but has anyone had this happen and could you tell me how I can get my window back up? It is not the motor in the window, it is because these codes were thrown. I had my EBCM rebuilt and installed in May, and no problems to date except now. Any feedback to get my window back up would be greatly appreciated.
Thank you in advance.
JG853
JG853 is offline   Reply With Quote
Old 10-23-2007, 12:37 AM   #2 (permalink)
-X-
Re: Drivers window will not go up
First thing I would do is clear the code for the window, then try using the up button again. How much voltage is the battery yielding? Make sure the battery terminals are securely fastened; it might be time for a new/better battery, or maybe you have a bad ground somewhere. Search the forums.
-X- is offline   Reply With Quote
Old 10-23-2007, 02:43 PM   #3 (permalink)
Thanks - Cleared the codes, letit sit over night and also tightened the posts on my Odessey battery and all is good!!
Thanks
JG853
Old 10-23-2007, 06:48 PM   #4 (permalink)
-X-
No problem, glad it worked out for you.
Drivers side window makes a grinding sound Dylan C5 Z06 - Pit Road 0 12-21-2006 04:07 PM
DS window not working, module or window switch? eviLS6 C5 Z06 - Pit Road 4 07-09-2006 11:34 AM
Anyone experience sand caught in the side window felt scratching the window? piker C5 Z06 - Grandstand 11 03-04-2006 11:07 PM
Need advice re: back window scratched by window tinter roushraven C5 Z06 - Grandstand 34 02-06-2004 10:41 PM
Drivers side window scratch!! rpallas C5 Z06 - Grandstand 5 04-08-2003 08:58 PM
