Old 08-02-2004, 07:37 PM   #1 (permalink)
Send a message via ICQ to Dixit Send a message via AIM to Dixit Send a message via MSN to Dixit Send a message via Yahoo to Dixit
Getting Misfire code, is this normal on cam setup?
Well what I mean is that when I first cleared the code I didnt get it even on my 300 mile drive. Not straight highway, here and there, stopped at a hotel drove 160 the next day. Still never got it.
It seems during the hot starts with my cam, I know I have to fight the idle for about 1min. Not a big issue, but once its running, even in this hot ATL weather if Im driving through traffic, I get a check engine light and heres come the misfire code again.
So for the past 2 times its always happened in traffic while in stop and go traffic light traffic.
Im just wondering if this is because of the hot weather and the a228/232 112lsa cam I got sitting in there?
Or should I consider taking this to the dealer or get it re-tuned again?
Dixit
AFR205cc 66cc heads, Crane 228/232 112LSA .600" Lift CAM, Ported FAST 90,
Ported LS2 90mm TB, Nasty Performance Fuel Rails. Kooks headers,
Magnaflow Exhaust, Hurst Short shifter, 5% Tint, Breathless Performance hood,
CCW 505A wheels, PIAA 1100x, Eclipse AVN5495 Nav unit, Rainbow Audio
Dixit is offline   Reply With Quote
Old 08-03-2004, 10:50 AM   #2 (permalink)
Banned
You need to find out what is causing the misfire code. It could be any number of reasons why the code appears. I would not ignore it. Misfire codes should be taken very seriously.
As far as the Hot Starts, you need some fine tuning via LS1 Edit to solve that issue. Perhaps this is causing the code or it could be 2 separate issues.
Best of luck...
Les
FUBU69 is offline   Reply With Quote
Old 08-03-2004, 11:07 AM   #3 (permalink)
The only wierd thing I have gotten is the low oil level sometimes even though the dipstick shows full. The hot start issue was resolved with some tuning from Andy at 21st Century Muscles cars. They do a great job there.
Chris
Nothing brings people together more than mutual hatred!
CJZ06 is offline   Reply With Quote
Old 08-03-2004, 11:12 AM   #4 (permalink)
Yea I got a low oil level as well, I got a feeling might have got that because the car was rocking so hard it throws the sensor off.
Its just really odd how it only comes back when its at idle on a really hot day. I will probably have to take it to the local GM stealership to let them handle it since its under warranty and the cam was installed by a GM certified tech. So they warranty the whole thing.
Dixit
Old 08-03-2004, 11:53 AM   #5 (permalink)
Let me know what you get figured out on the low oil thing. That is a great looking car. I have a Yellow Z also.
Chris
Old 08-03-2004, 05:05 PM   #6 (permalink)
Oddly enough today leaving home from work the check engine light went off on its own. So now this is totally baffling. Only thing I can assume its not a major thing then. Must be cam/hot start related.
Dixit
Old 08-04-2004, 01:03 PM   #7 (permalink)
Banned
I would still have it diagnosed. I had a 224/228/583 Cam along with very aggressive Stage 2 Heads and did not have any codes or Hot Starts.
When my Z06 was a bolt on car, I experienced a short in my injector wiring harness. The engine light would appear and go away. The harness wiring was too tight and the metal clips were piercing through the wires causing my injector(s) to stay open and dump fuel into the cylinder(s). I hydro-locked my engine with fuel.
GM extended the wiring harness from the '03 models forward.
Best of luck,
Les
Old 08-04-2004, 01:22 PM   #8 (permalink)
Will do Les, but going to be hard to prove the point when the code is gone unless I force a misfire by pulling a plug for a few minutes
Dixit
Old 08-04-2004, 01:40 PM   #9 (permalink)
Banned
Dixit
Dixit,
even though your engine light is now off, you should be able to retieve the old codes via your DIC. These codes should/could be retrieved in the "History" mode when prompting codes through your DIC. The old codes have a "H" at the end.
Hope this helps.
Les
Old 08-04-2004, 01:48 PM   #10 (permalink)
What fully clears it out of History? Only reason I ask that is I remember someone posting on z06vette about clearing their Check engine light before going into emmissions and they still caught it. Does that mean they are also checking history?
I remember this person saying it takes 100miles to clear the code completely even after clearing it manually. Is this true?
Dixit
Old 08-04-2004, 07:43 PM   #11 (permalink)
Ernie King's Avatar
Dixit,
You said the dealer installed the cam?? How did they tunes the car? (PCM) unless they have Ls1 edit I wouldn't think they did.
You sound like your running pig rich. If you running a cam with stock PCM tune I don't think your car will run that well.
Find some one that can tune it properly and you should be good to go.
BTW, I just had my car done (emissions) and 1/2 way to the place my check engine light came on, I cleared the code and it went right through.
Ernie
2000 FRC Nassau Blue
10 Second Club
Multiple Cylinder Misfire code thrown kmagvette C5 Z06 - Pit Road 3 11-22-2005 10:31 PM
Error code P0300 misfire? Nate C5 Z06 - Pit Road 3 08-09-2004 05:25 PM
Heads And Cam Setup. CraZee ZO6 C5 Z06 - Grandstand 13 02-11-2004 09:48 PM
Could a misfire occur without throwing a Check Engine Light & code? RC45 C5 Z06 - Pit Road 6 02-08-2003 03:50 PM
Intermittant misfire code racingfast C5 Z06 - Pit Road 2 11-15-2002 10:56 AM
