Old 08-03-2008, 09:20 AM   #1 (permalink)
Help with code 1214
My '02 ZO6 has been plagued recently with the no ABS, no Active Handling messages and code 1214. I have the factory services manauls but they are not of much help other than to replace the EBCM. Are there any partcular grounds to check and where are they? I'm hoping that it's just a loose wire somwhere.
ZO6 Bryan is offline   Reply With Quote
Old 08-03-2008, 03:42 PM   #2 (permalink)
Re: Help with code 1214
How many miles on car?- could be grounds but could be abs module. Pull the module off the brake module and send to absfixer. I dont know if they are a supporting vendor but they cured the problem on my vette at 1/4 the cost the dealer wanted. pm me if you want more info.
zblack blur is offline   Reply With Quote
Old 08-03-2008, 04:53 PM   #3 (permalink)
It only has 30K miles on it. Garage kept so not alot of corrosion under the hood. I went ahead and pulled the module and checked the wires for damage and saw none. I'm sending it off to absfixer tomorrow. Only $150 to fix it.
We'll see how it goes. Hope that's all it is and it's not the brake pressure module.
Old 08-03-2008, 07:57 PM   #4 (permalink)
dwjZ06's Avatar
^ Mine went at 32,000. Common problem. It should fix you right up. Don
SIG by GR8 WHITE
Old 08-06-2008, 05:54 PM   #5 (permalink)
Originally Posted by dz999 View Post
My ABS controller went out too! Some problems can be fixed by ABSFixer; like relays and transistors, but it depends on how it fails. I think he gives you a list of trouble codes that can be repaired. I had to buy a new one. GM wants about $800 dollars but if you shop around on ebay they can be had for $500. Still a lot!
Mine has been repaired and is on it's way back already.
Old 08-06-2008, 06:16 PM   #6 (permalink)
RocketSled's Avatar
The EBCM failure seems to be more a factor of age than actual miles. But like as not, you're getting the 1214 code and the fix will be a new EBCM. It was for me...
C6!
Old 08-11-2008, 07:25 PM   #7 (permalink)
I got my EBCM back on Friday and plugged it back in and no codes! Not bad for only $150 after the dealer wanted $1300. Obviously it was the module responsible and not a bad ground or broken wire.
Code 1214 and TX state inspection DonWarren C5 Z06 - Pit Road 9 11-03-2006 12:02 PM
troubleshooting code B0026 (airbag code) fusion_ta66 C5 Z06 - Tuning & Electronics 6 07-14-2006 03:31 AM
I got a code that's not on any code list??? Morzoff C5 Z06 - Tuning & Electronics 4 08-14-2005 07:16 AM
Zip Code GroundFighter The Garage 6 06-27-2002 08:01 PM
Anyone know what this code is? Silver Ghost C5 Z06 - Pit Road 6 06-16-2002 01:56 AM
