Old 07-21-2007, 01:10 PM   #1 (permalink)
Red Kelly's Avatar
Help with Electrical Problem.
I've heard of batteries going unexpectedly but this problem is different. My 02 battery is good and never had any problems.
I took my son to his soccer game last night and after the game the Z wouldn’t start. There was no power, no lights, no clicking, nothing. It was like someone removed the battery. I got a boost and it started right away but the headlights wouldn’t come on. I installed the Specter Werkes HID lights back in 02 without any problems. The high beams would work but the low beams wouldn’t. As I was driving home I saw the low beams flicker on twice. When I got home the low beams came on. I turned off the car and tried to restart it. It was completely dead like before. I checked the battery connection for a loose ground and everything is tight. I checked the headlight wiring and everything is good.
Any idea’s???
NCM 13458 - 02, Z06, EB, Halltech Tunnel Ram, Breathless TB, Hypertech 160 TS, FLP Headers, x-pipe, Borla Stingers, 392.1 RWHP - 375.7 RWTQ SAE
Red Kelly is offline   Reply With Quote
Old 07-21-2007, 02:08 PM   #2 (permalink)
Red Kelly's Avatar
Re: Help with Electrical Problem.
I just reconnected my battery and hear this ticking sound below the battery. Kinda sounds like a turn signal. The instrument panel is dead, no lights....
Old 07-21-2007, 02:36 PM   #3 (permalink)
I had a similar problem, with my 2002. I changed the battery and that took care of it.
sleeprobber is offline   Reply With Quote
Old 07-21-2007, 03:40 PM   #4 (permalink)
extanker's Avatar
using a DVOM what does it read [batt.]
Old 07-21-2007, 04:02 PM   #5 (permalink)
When you say "my 02 battery is good, never had any problems", does that mean it's the original battery? If so, time for a new battery.
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Old 07-21-2007, 04:02 PM   #6 (permalink)
Mine went the same way. One minute it was fine and the next it was like it was gone. A new battery is in order.
Steve Odian
02 TR/Mod Red, Ron Fellow's autographed coil pack cover, CAGS defeat, ZO6 exhaust plate, Z06 405 throttle body plate, magnetic plug, shorty antenna, and 12 disc CD changer.
sodian is offline   Reply With Quote
Old 07-21-2007, 04:17 PM   #7 (permalink)
I'd bet you a nickle you put in a new battery and all will be back to normal.
KJN VET is offline   Reply With Quote
Old 07-21-2007, 04:20 PM   #8 (permalink)
You're looooong overdue!
Sig by the Hillbilly!
Old 07-21-2007, 11:05 PM   #9 (permalink)
MillYELLZ's Avatar
Def. sounds like a dead battery to me. Simple fix my man. Good luck with it.
'02 MY Z (Mods Coming)
'93 Single turbo Rx-7 412 rwhp
MillYELLZ is offline   Reply With Quote
Old 07-22-2007, 08:04 AM   #10 (permalink)
Red Kelly's Avatar
Well all you guys are right! My buddy came over and did an electrical test on the battery. It read 12.34 volts out of the car but 7.78 volts installed. I bought a new battery and she fired up immediately.
After the install she started throwing codes.
28-TCS - 1 code - C1214 HC (could not clear)
40-BCM - 11 codes (cleared)
AO-LDCM - 3 codes (cleared)
A1-RDCM - 3 codes (cleared)
A6- SCM - 1 code (cleared)
Prior to the battery dying I had ABS, TCS and Active Handling codes which I cleared from time to time but now I can't clear. I have all the symptoms that my shop manual states. So I guess I need a scan tool to clear these codes
Old 07-22-2007, 02:54 PM   #11 (permalink)
RocketSled's Avatar
The codes with the "C" in them can't be cleared because they're "active", the problem is still happening. A scan tool won't help you, there's something really wrong with your TCS.
I think the C1214 error is symptomatic of a known issue with the EBCM. Search the forum for 1214 and EBCM and I'm sure you'll get plenty of hits.
C6!
Old 07-23-2007, 04:19 AM   #12 (permalink)
Red Kelly's Avatar
That doesn't sound good. I think it's time I call up my dealer and have them look at this. Last time I took it to the dealer for column lock, they reflashed my PCM and I lost my custom tune. Thanks for the info
Electrical problem!! My Z needs help! xtremejimmy C5 Z06 - Pit Road 6 11-19-2006 06:09 PM
Electrical Problem Symptoms EB02Z C5 Z06 - Pit Road 6 05-07-2006 04:49 PM
Found the electrical problem! 2002Z06Yellow C5 Z06 - Pit Road 1 11-21-2005 04:18 PM
Electrical problem 2002Z06Yellow C5 Z06 - Pit Road 12 01-10-2005 09:57 PM
Possible Electrical problem VettTheRipper C5 Z06 - Pit Road 7 05-14-2002 06:54 PM
