Old 07-06-2009, 07:19 PM   #1 (permalink)
HID light
can someone let me in on how to run HID light in my 2001 Z06 with out the alarm going all crazy!!!
scotts405HP is offline   Reply With Quote
Old 07-07-2009, 12:21 PM   #2 (permalink)
Re: HID light
I assume your talking about HID headlights?? This is causing your car alarm to go haywire??
Old 07-07-2009, 01:18 PM   #3 (permalink)
Re: HID light
yes and the light will pop up but not go down? and the alarm beeps at you every time you get in or out of the car!
Old 07-07-2009, 01:42 PM   #4 (permalink)
RocketSled's Avatar
Re: HID light
Did you buy a kit, or just some lamps that you hooked up yourself?
I can't give you any help on the alarm going off when you get in/out of the car. Never heard of anyone having that problem before - not sure how it would relate to the headlamp issue unless you have a fundamental wiring issue.
But... the symptom of the headlamps not going down is a design feature. The BCM checks for continuity on the headlamp circuit and will refuse to retract a headlamp if that continuity check fails. It's the car's way of saying "Hey, I think a headlamp is burned out". Many aftermarket headlamp kits replace the primary headlamps in the circuit with a relay, and then use that relay to drive the higher power aftermarket lamps. The BCM doesn't know how to check that new, secondary circuit, it still checks the primary circuit and the replacement relay doesn't present the "right" resistive load and that causes the BCM to think that a bulb is burned out.
Assuming the HIDs you installed were a kit, and not something you cobbled together on your own, call the manufacturer and complain and I bet they have a fix for the issue. If you did put your own kit together, you could still probably call someone who makes a system and explain your problem and get them to sell you a dummy resistive load to put in your circuit to correct the problem.
Also, if you did design your own HID setup, I would carefully review the hookup in an effort to determine why the alarm goes off. Troubleshooting 101 - disconnect the HIDs and see if the alarm problem persists!
C6!
Old 07-07-2009, 02:20 PM   #5 (permalink)
Re: HID light
Probably something in the 2-4 K range 1/2-1/4 W would do the job if you knew where to put it..
Hey Rocket ... what is BCM am acronym for...I do not have a service manual
Montana: So Many Z06 Roads...So Little Time Z06/Z16#1571
maineyak_2000 is offline   Reply With Quote
Old 07-07-2009, 02:32 PM   #6 (permalink)
Re: HID light
To add to what Rocket has already said, I had to install a dummy 'load resistor' when I installed my HID kit to get the lamps to retract when I turned the switch to the off position. I found that you actually only need one of these resistors in the HID circuit to make the lamps retract (i.e. a single resistor installed on the left or right HID lamp circuit), but I installed one on both sides anyways.
Make sure the resistor that they recommend/you buy is of the large heat-dissapating kind. Cant remember the resistance value, but mine are about 2.5" long and 0.5" tall. I might still have a link to the website I bought mine from if you want it, I can PM you.
To take a guess at your horn/alarm problem, I would say that its unrelated to the installation of your HIDs (unless its honking/alarming because it thinks you have a headlight out, which I doubt. If so, the dummy resistor(s) will solve this problem). I know that if you have the cars DIC lock mode set for "Horn & Lights" or "Horn", it will honk once everytime you use the key fob to lock the car. Maybe this is what your experiencing...????
Old 07-07-2009, 05:55 PM   #7 (permalink)
Re: HID light
I would like the see the web page you have LeRox. Im useing a kit thats plug and play. all you need to do is plug it in from the fact. light into the balist and then plug the balist into the light. I think I need a resistor to make the light work( I think its thinking a light is out)
Old 07-07-2009, 06:26 PM   #8 (permalink)
RocketSled's Avatar
Re: HID light
maineyak_2000, the acronym "BCM" stands for "Body Control Module".
Old 07-07-2009, 10:15 PM   #9 (permalink)
Re: HID light
can some-one tell me how to set up the resister or have info on step by step install to use for the resister install? and if you have a good website to go to and get the resister?
Old 07-07-2009, 11:35 PM   #10 (permalink)
Re: HID light
PM sent to you scotts....
Old 07-07-2009, 11:58 PM   #11 (permalink)
Re: HID light
Heres a pic of how to wire in the resistor....it taps in across the two aftermarket HID harness wires. Just make sure you mount the resistor on something metal and away from the wires and anything plastic, cause it supposedly gets pretty warm.
Old 07-08-2009, 05:58 PM   #12 (permalink)
Re: HID light
thanks for all your help!!!! can someone tell me what resistor I need to get?
Old 07-09-2009, 12:06 PM   #13 (permalink)
Re: HID light
Scott, I sent you a private message (PM) with a link to the resistors that I bought/am using.....
Old 10-15-2009, 09:08 AM   #14 (permalink)
Banned
Re: HID light
***edited***
You have signed up on almost every car and motorcycle forum in existance over the last 2 days in each case acting like you were a newbie asking for advice on HID installation while at the same time advertising your company.
You are not a site vendor here nor do we allow vendors who are that dishonest to sign up as vendors here
mikegps2009 is offline   Reply With Quote
Old 10-15-2009, 10:21 AM   #15 (permalink)
Re: HID light
No problem. Let me know if I can help you with any other issues with wiring your HIDs
HID light pattern S-TEE C5 Z06 - Pit Road 10 03-09-2006 06:31 PM
How does one go HID? Zed C5 Z06 - Pit Road 20 01-14-2004 04:27 PM
HID for C6 paulf1 C6 Z06 - Grandstand 5 10-16-2003 07:16 PM
HID Light Anyone? Sickdriver Vendor Sales - C5 17 09-22-2003 04:12 PM
CATZ HID Light Kit CCRider C5 Z06 - Pit Road 2 04-03-2003 10:44 PM
» Latest Auto News
Recall Notice: Toyota Officially Recalls 2010 Prius and Lexus HS250h for ABS Brake Issues
As expected, Toyota has announced a recall for the 2010 Prius hybrid,
Furious Fuchsia Dodge Challenger Celebrates 40 Years of a Muscle-Car Icon
Dodge is once again releasing a new special edition versions of its
Chicago Preview: Nissan 370Z 40th Anniversary Edition Set for World Premiere in Chicago
Just last week we thought we’d have to wait for the New York
» New Car Reviews
2010 Lamborghini LP560-4 Spyder Review
With Lambo's new LP560 Spyder, taming the bull has never been so easy,
2010 Nissan Pathfinder SE 4x4 Review
Nissan's rugged Pathfinder is an old-school standout
2010 Chicago Auto Show Preview
The Chicago Auto Show might not have the media hype of such events as
2010 Toyota Camry SE V6 Review
An SE trim level adds a little sport to the Camry, making living with
2010 Subaru Legacy 2.5i Premium PZEV
Subaru's 2010 Legacy gives up some of the brand's more endearing
