Old 02-15-2008, 11:36 AM   #1 (permalink)
bbullitt01's Avatar
P0160HC Code
Heated Oxygen Sensor Bank 2 Sensor 2-B
This is the code I have seen popping up.
I am replacing the stock manifolds with long tubes and high flow cats. I should replace this sensor while I am at it.
Which one is it?
Pre Cat or downstream of Cat?
Passenger or Drivers side?
Thanks!
bbullitt01 is offline   Reply With Quote
Old 02-15-2008, 01:34 PM   #2 (permalink)
RocketSled's Avatar
Re: P0160HC Code
Bank 1 are the sensors on the left side pipe (driver's side). Bank 2 are the sensors on the right side pipe. Note the cable routing is opposite, the cable for the left hand pipe is routed down the right hand side... Sensor 1s are ahead of the Cats, sensor 2s are after the Cat.
Yes, you should probably replace the sensor. You should consider replacing both sides... For parts the come in pairs, failure of one is often a precursor to failure of another.
C6!
Old 02-17-2008, 07:29 AM   #3 (permalink)
bbullitt01's Avatar
Re: P0160HC Code
Thanks for that.
I learned that code relates to the sensors UPSTREAM of the cats. Apparently pre cat sensors are heated, post cat are not. I'm not really sure what that means, but that is what I was told at the parts store. ?
Old 02-17-2008, 09:22 AM   #4 (permalink)
Speedratchet's Avatar
Re: P0160HC Code
P0160 Info
Visit me at: Speedratchet
Old 02-17-2008, 09:26 AM   #5 (permalink)
bbullitt01's Avatar
Re: P0160HC Code
troubleshooting code B0026 (airbag code) fusion_ta66 C5 Z06 - Tuning & Electronics 6 07-14-2006 03:31 AM
The Man Code Roadracer247 The Garage 2 12-04-2005 09:16 PM
I got a code that's not on any code list??? Morzoff C5 Z06 - Tuning & Electronics 4 08-14-2005 07:16 AM
need code help. VNVETT C5 Z06 - Pit Road 1 08-13-2005 11:52 AM
IPC code The Flame C5 Z06 - Pit Road 0 07-21-2002 12:08 PM
