P0410 code help
My car kicked a P0410 code today (secondary air system). From my search of the forum I've read that this is a "non-functioning" system and only used for cold starts. Could this also be an EGR leak coming from the tube that branches off from the headers? This is my suspected cause.
thx,
Jim
***EDIT*** Ok, my passenger side EGR tube was leaking at the point where it hooks up to the header. I replaced the gasket and re-torqed everything. Just for S&G's, I looked at the eng ign 1 and air pump fuses, pulled them out (they were fine), and reset them. Hopped back into the car to reset the code and it was gone. Guessing fixing the EGR leak fixed the problem.
Reason: I solved the problem
